Ga door naar hoofdinhoud
Pantech Burst Motherboard Replacement
Wat je nodig hebt
  1. Pantech Burst Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 3 Pantech Burst Motherboard Replacement, Motherboard: stap 1, afbeelding 2 van 3 Pantech Burst Motherboard Replacement, Motherboard: stap 1, afbeelding 3 van 3
    • Power off your phone before beginning disassembly.
    • Turn over the phone so that you're facing the back cover.
    • Locate the indent(?) below the back cover.
    • Using a fingernail, pull up to remove the back cover.
    • Removing the back cover may require some force.
  2. Pantech Burst Motherboard Replacement: stap 2, afbeelding 1 van 3 Pantech Burst Motherboard Replacement: stap 2, afbeelding 2 van 3 Pantech Burst Motherboard Replacement: stap 2, afbeelding 3 van 3
    • Locate the silver battery. It is the big, rectangular, silver tape on black plastic object.
    • Find the gap between the battery and the rest of the device.
    • Using your fingernail, gently pull the battery up and away from the rest of the device.
  3. Pantech Burst Motherboard Replacement: stap 3, afbeelding 1 van 3 Pantech Burst Motherboard Replacement: stap 3, afbeelding 2 van 3 Pantech Burst Motherboard Replacement: stap 3, afbeelding 3 van 3
    • Undo all 8 visible screws using a phillips size 000 screwdriver.
    • The screws are marked in red on the picture.
  4. Pantech Burst Motherboard Replacement: stap 4, afbeelding 1 van 2 Pantech Burst Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Remove the SD card if there is one inserted into the phone.
  5. Pantech Burst Motherboard Replacement: stap 5, afbeelding 1 van 3 Pantech Burst Motherboard Replacement: stap 5, afbeelding 2 van 3 Pantech Burst Motherboard Replacement: stap 5, afbeelding 3 van 3
    • Using an opening tool or some other solid, flat-ended tool, begin pulling apart the phone from the indent below the USB port.
    • Continue using the tool, while moving around the edge of the phone until the two parts are largely disengaged.
    • Once there is space enough to pull the pieces apart with your fingers, you may do so.
    • Opening the phone may require a good amount of force.
  6. Pantech Burst Motherboard Replacement: stap 6, afbeelding 1 van 3 Pantech Burst Motherboard Replacement: stap 6, afbeelding 2 van 3 Pantech Burst Motherboard Replacement: stap 6, afbeelding 3 van 3
    • Unscrew the screw with a phillips size 000 screwdriver.
    • Disconnect the blue connector from the motherboard using a fingernail to lightly pull up.
    • Gently remove the SIM/SD card part.
  7. Pantech Burst Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Gently disconnect the connectors attached to the motherboard using a fingernail to pull them up from the board.
    • Connectors are marked in blue in the image.
  8. Pantech Burst Motherboard Replacement: stap 8, afbeelding 1 van 3 Pantech Burst Motherboard Replacement: stap 8, afbeelding 2 van 3 Pantech Burst Motherboard Replacement: stap 8, afbeelding 3 van 3
    • Starting from the bottom and going around counterclockwise, carefully pry the motherboard out of the device.
    • Beginning with the side with the USB port may damage the phone.
Conclusie
Kyle Kurashima
111 Reputatie
1 Handleiding geschreven
Cal Poly, Team 15-1, Green Fall 2015 Lid van Cal Poly, Team 15-1, Green Fall 2015
CPSU-GREEN-F15S15G1
5 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 16
Altijd: 435
