Ga door naar hoofdinhoud
Pantech Breakout Battery Replacement
Wat je nodig hebt
  1. Pantech Breakout Battery Replacement, Removing Back Cover: stap 1, afbeelding 1 van 3 Pantech Breakout Battery Replacement, Removing Back Cover: stap 1, afbeelding 2 van 3 Pantech Breakout Battery Replacement, Removing Back Cover: stap 1, afbeelding 3 van 3
    • Before proceeding, completely power off phone and disconnect power cords to avoid electrical shock.
    • Turn phone over so that the back side is facing up.
    • Using a finger, apply moderate pressure to the top of the back cover while sliding the cover down and off.
    • Lift and remove the back cover from the phone.
  2. Pantech Breakout Battery Replacement, Removing the Battery: stap 2, afbeelding 1 van 2 Pantech Breakout Battery Replacement, Removing the Battery: stap 2, afbeelding 2 van 2
    • Locate the battery: It is a silver, rectangular object.
    • Insert a fingernail into the indent just below the battery about 0.5 inches from the bottom of the phone.
    • Then, apply pressure to the battery, pushing up and away from the phone. It will come out easily.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Ryan Murphy
898 Reputatie
7 handleidingen geschreven
USF Tampa, Team 5-5, Mcgee Fall 2014 Lid van USF Tampa, Team 5-5, Mcgee Fall 2014
USFT-MCGEE-F14S5G5
4 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 1,911
