Ga door naar hoofdinhoud
Pandigital Super Nova Front Facing Camera Replacement
Wat je nodig hebt
  1. Pandigital Super Nova Front Facing Camera Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove the screw covers from each corner of the back side of the device.
    • Set aside.
  2. Pandigital Super Nova Front Facing Camera Replacement: stap 2, afbeelding 1 van 2 Pandigital Super Nova Front Facing Camera Replacement: stap 2, afbeelding 2 van 2
    • Using a Philips screwdriver, remove all four .15 mm screws from each corner.
    • Set aside.
  3. Pandigital Super Nova Front Facing Camera Replacement: stap 3, afbeelding 1 van 1
    • Using the plastic opening tool, remove the back cover of the device.
  4. Pandigital Super Nova Front Facing Camera Replacement: stap 4, afbeelding 1 van 1
    • Remove the three .11 mm screws that hold the battery in place.
    • Set aside.
  5. Pandigital Super Nova Front Facing Camera Replacement: stap 5, afbeelding 1 van 2 Pandigital Super Nova Front Facing Camera Replacement: stap 5, afbeelding 2 van 2
    • Unplug the battery and remove from device.
    • Avoid touching the motherboard as it is fragile.
  6. Pandigital Super Nova Front Facing Camera Replacement, Front Facing Camera: stap 6, afbeelding 1 van 2 Pandigital Super Nova Front Facing Camera Replacement, Front Facing Camera: stap 6, afbeelding 2 van 2
    • Use a metal pry tool to separate the camera and the small clip that holds it in place.
    • Do NOT touch the MotherBoard with your bare hands. There is risk of short circuiting the device. Use nitrile gloves to prevent this.
  7. Pandigital Super Nova Front Facing Camera Replacement: stap 7, afbeelding 1 van 2 Pandigital Super Nova Front Facing Camera Replacement: stap 7, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Use a pair of small tweezers to gently pull the camera connector out of the motherboard.
Conclusie
sterling hannsz
267 Reputatie
2 handleidingen geschreven
Texas Tech, Team 1-2, Bennett Fall 2016 Lid van Texas Tech, Team 1-2, Bennett Fall 2016
TTU-BENNETT-F16S1G2
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 109
