Wat je nodig hebt
Now with the device opened, we need to disconnect power.
Disconnect the four plugs on the "power board". Each of them is of a unique size, so you can't mix them up.
However, the two plugs (later three) on the "connector board" are practically identical, and are only different in the order of the wires connected.
Don't mix those up.
The next step to separate the two halves involving disconnecting
tentacles and umbilical cordsthe grounding line. -
Fun fact -- the device has the power supplied through a two-prong plug, meaning there is no "true" GrouND.
This mystery is deepened by the fact that only the "CD board" have this "ground" cable at one of the screw posts.
.. so the bottom half slides away.
Apparently the top half houses all the brain, since there are quite a few green PCBs and two large, dense boards.
We can make our lives easier by trying to remove the two white piece.
Apparently there is something holding them, since they refuse to move under slight tugs that aims to unseat them.
And those come from ... behind the handle?
So, how do you remove the handle?
Well, if you flip to the side, you can see the joint of the handle.
And immediately next to the joint, is a "flap".
And if you depress this flap, this creates a channel, through which the handle can be slide backwards (and out of the hinge)
And THAT will give us access to this screw, which is required to remove the "white piece"s.
Next up we remove the "CD board".
Why the CD board?
I don't know. It will be a good question to think about while we pop the connectors and remove the screws.
Or wonder about what the ICs behind the heatsink/label actually do.
I bet the one behind the label is a storage unit, like ones in a flash drive.
