Ga door naar hoofdinhoud
Panasonic Toughbook CF-53 Optical Drive Replacement
Wat je nodig hebt
  1. Panasonic Toughbook CF-53 Optical Drive Replacement, Optical Drive: stap 1, afbeelding 1 van 2 Panasonic Toughbook CF-53 Optical Drive Replacement, Optical Drive: stap 1, afbeelding 2 van 2
    • Orient the laptop onto its top and face the bottom towards you.
    • Remove the 3 mm Phillips #00 screws securing the Wi-Fi card/optical drive plastic cover.
  2. Panasonic Toughbook CF-53 Optical Drive Replacement: stap 2, afbeelding 1 van 1
    • Remove the 5 mm Phillips #00 screw on the silver tab to the left.
  3. Panasonic Toughbook CF-53 Optical Drive Replacement: stap 3, afbeelding 1 van 1
    • Reach under the silver tab and push the optical drive out of the side of the device using a spudger.
  4. Panasonic Toughbook CF-53 Optical Drive Replacement: stap 4, afbeelding 1 van 1
    • Now that the drive is completely disconnected from the device, slide the optical drive out of its slot.
    • The end of the drive may seem to be stuck inside the device during removal. If this is the case gently wiggle the drive side to side and apply a small force until it pops free.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 15
Altijd: 1,552
