Ga door naar hoofdinhoud
Panasonic Toughbook CF-53 Battery Replacement
  1. Panasonic Toughbook CF-53 Battery Replacement, Battery: stap 1, afbeelding 1 van 3 Panasonic Toughbook CF-53 Battery Replacement, Battery: stap 1, afbeelding 2 van 3 Panasonic Toughbook CF-53 Battery Replacement, Battery: stap 1, afbeelding 3 van 3
    • Orient the laptop on its side so that the plastic battery cover is facing upward.
    • Push down on the battery cover and remove it by sliding the cover down. This may take some force, but the cover should pop up with a soft click.
  2. Panasonic Toughbook CF-53 Battery Replacement: stap 2, afbeelding 1 van 2 Panasonic Toughbook CF-53 Battery Replacement: stap 2, afbeelding 2 van 2
    • Use the battery release slider to release the battery latch.
  3. Panasonic Toughbook CF-53 Battery Replacement: stap 3, afbeelding 1 van 3 Panasonic Toughbook CF-53 Battery Replacement: stap 3, afbeelding 2 van 3 Panasonic Toughbook CF-53 Battery Replacement: stap 3, afbeelding 3 van 3
    • Use the blue tab to pull the battery out of the battery compartment. Make sure to keep the battery latch tab depressed while doing so.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Één opmerking
I replaced the battery compatible one and replace the power adapter as well but still shows no power. What other issues may cause no power?
Rick Reeves - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 94
Altijd: 6,008
