Ga door naar hoofdinhoud
Panasonic Toughbook CF-29 Trackpad Board Replacement
Wat je nodig hebt
  1. Panasonic Toughbook CF-29 Trackpad Board Replacement, Battery: stap 1, afbeelding 1 van 1
    • Locate the bay door for the battery on the left side of the laptop.
  2. Panasonic Toughbook CF-29 Trackpad Board Replacement: stap 2, afbeelding 1 van 2 Panasonic Toughbook CF-29 Trackpad Board Replacement: stap 2, afbeelding 2 van 2
    • Slide the latch to the right and then down to unlock it.
    • Pull out the battery.
  3. Panasonic Toughbook CF-29 Trackpad Board Replacement, Hard Drive: stap 3, afbeelding 1 van 1
    • Locate the door for the hard drive on the right side of the laptop
  4. Panasonic Toughbook CF-29 Trackpad Board Replacement: stap 4, afbeelding 1 van 2 Panasonic Toughbook CF-29 Trackpad Board Replacement: stap 4, afbeelding 2 van 2
    • Push and slide the latch up to open the hard drive door.
    • Pull out the hard drive.
  5. Panasonic Toughbook CF-29 Trackpad Board Replacement, Optical Drive: stap 5, afbeelding 1 van 1
    • Flip the device upside down with the handle facing away from you.
    • Open the optical drive bay by sliding its latch to the right.
    • Locate optical drive release mechanism on the bottom of the laptop.
  6. Panasonic Toughbook CF-29 Trackpad Board Replacement: stap 6, afbeelding 1 van 1
    • Slide the latch cover to the right.
  7. Panasonic Toughbook CF-29 Trackpad Board Replacement: stap 7, afbeelding 1 van 2 Panasonic Toughbook CF-29 Trackpad Board Replacement: stap 7, afbeelding 2 van 2
    • Push the exposed switch to the left to eject the optical drive.
  8. Panasonic Toughbook CF-29 Trackpad Board Replacement, Back Cover: stap 8, afbeelding 1 van 1
    • Begin by turning the laptop upside down with the handle towards you.
    • Use a Phillips size 0 screwdriver to remove the 4 screws holding down the ram cover.
  9. Panasonic Toughbook CF-29 Trackpad Board Replacement: stap 9, afbeelding 1 van 1
    • Remove the panel and set it aside.
    • Use a Phillips size 0 screwdriver to remove these 8 small screws.
  10. Panasonic Toughbook CF-29 Trackpad Board Replacement: stap 10, afbeelding 1 van 1
    • Use a Phillips size 1 screwdriver to remove the remaining 8 screws.
  11. Panasonic Toughbook CF-29 Trackpad Board Replacement: stap 11, afbeelding 1 van 2 Panasonic Toughbook CF-29 Trackpad Board Replacement: stap 11, afbeelding 2 van 2
    • Use a plastic opening tool to release, but NOT remove, the back cover because it is sealed with adhesive.
  12. Panasonic Toughbook CF-29 Trackpad Board Replacement: stap 12, afbeelding 1 van 1
    • Be careful when lifting the cover as you may damage some connections.
    • Slowly lift the cover so that you can disconnect the red and white wires connecting the speaker to the sound card.
  13. Panasonic Toughbook CF-29 Trackpad Board Replacement: stap 13, afbeelding 1 van 1
    • Now the back cover should be off and you can access the inside of the casing.
  14. Panasonic Toughbook CF-29 Trackpad Board Replacement, Trackpad Board: stap 14, afbeelding 1 van 1
    • Locate the track pad chip near the handle.
    • Remove the upper right screw.
  15. Panasonic Toughbook CF-29 Trackpad Board Replacement: stap 15, afbeelding 1 van 1
    • Use a pry bar to detach the white ribbon cable shown.
    • Push the brown tab to release the cable
  16. Panasonic Toughbook CF-29 Trackpad Board Replacement: stap 16, afbeelding 1 van 1
    • Remove the screw that was previously concealed under the now removed ribbon cable.
  17. Panasonic Toughbook CF-29 Trackpad Board Replacement: stap 17, afbeelding 1 van 1
    • Remove the rightmost ribbon cable
    • Pry up the brown clip
    • Tug the cable out
  18. Panasonic Toughbook CF-29 Trackpad Board Replacement: stap 18, afbeelding 1 van 1
    • Pull the track pad slightly up and to the right.
    • Do not completely remove the circuit board because it is still attached.
  19. Panasonic Toughbook CF-29 Trackpad Board Replacement: stap 19, afbeelding 1 van 1
    • Remove the last ribbon cable.
    • Pry up on the brown part to release the ribbon cable.
  20. Panasonic Toughbook CF-29 Trackpad Board Replacement: stap 20, afbeelding 1 van 1
    • You have successfully removed the track pad board.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Dylan Bloom
373 Reputatie
4 handleidingen geschreven
Cal Poly, Team 27-93, Amido Spring 2010 Lid van Cal Poly, Team 27-93, Amido Spring 2010
CPSU-AMIDO-S10S27G93
4 Leden
26 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 23
Altijd: 5,823
