Ga door naar hoofdinhoud
Panasonic Toughbook CF-29 Touchscreen Replacement
Wat je nodig hebt
  1. Panasonic Toughbook CF-29 Touchscreen Replacement, Battery: stap 1, afbeelding 1 van 1
    • Locate the bay door for the battery on the left side of the laptop.
  2. Panasonic Toughbook CF-29 Touchscreen Replacement: stap 2, afbeelding 1 van 2 Panasonic Toughbook CF-29 Touchscreen Replacement: stap 2, afbeelding 2 van 2
    • Slide the latch to the right and then down to unlock it.
    • Pull out the battery.
  3. Panasonic Toughbook CF-29 Touchscreen Replacement, Touchscreen: stap 3, afbeelding 1 van 1
    • Remove the four hinge screws from the back of the computer.
  4. Panasonic Toughbook CF-29 Touchscreen Replacement: stap 4, afbeelding 1 van 2 Panasonic Toughbook CF-29 Touchscreen Replacement: stap 4, afbeelding 2 van 2
    • Open the laptop and remove the four indicated screws with a Phillips size 0 screwdriver.
    • Pry off the plastic strip which was previously held in place by the screws.
  5. Panasonic Toughbook CF-29 Touchscreen Replacement: stap 5, afbeelding 1 van 1
    • Remove the four hinge screws to allow the hinges to rotate up and move.
  6. Panasonic Toughbook CF-29 Touchscreen Replacement: stap 6, afbeelding 1 van 1
    • Remove 16 screws from the top of the closed laptop.
    • 12 Phillips size 1 screws
    • 2 Phillips size 0 screws
    • 2 Torx size 6 screws (T6)
    I found that the Torx screw on my model to be T8.
    Harley - Antwoord
    Is the touchscreen & the LCD 1 piece? or are they separate?
    Chasity Miller -
  7. Panasonic Toughbook CF-29 Touchscreen Replacement: stap 7, afbeelding 1 van 1
    • Gently break the adhesive seal between the front and rear display cases with a plastic opening tool.
    • You will need to reapply the silicon adhesive during reassembly to ensure watertight seal.
  8. Panasonic Toughbook CF-29 Touchscreen Replacement: stap 8, afbeelding 1 van 1
    • Pull the top halve of the casing up revealing the inside of the screen
  9. Panasonic Toughbook CF-29 Touchscreen Replacement: stap 9, afbeelding 1 van 2 Panasonic Toughbook CF-29 Touchscreen Replacement: stap 9, afbeelding 2 van 2
    • The top half of the case can be removed by sliding the tabs out from under the hinges.
    • This makes unplugging the screen wiring much easier
  10. Panasonic Toughbook CF-29 Touchscreen Replacement: stap 10, afbeelding 1 van 1
    • There are 4 wires that need to be unplugged to remove the screen.
  11. Panasonic Toughbook CF-29 Touchscreen Replacement: stap 11, afbeelding 1 van 1
    • For the first wire, peel back the silver cover tape to reveal the connection.
  12. Panasonic Toughbook CF-29 Touchscreen Replacement: stap 12, afbeelding 1 van 1
    • Pull the wiring away from the connection to release it.
  13. Panasonic Toughbook CF-29 Touchscreen Replacement: stap 13, afbeelding 1 van 1
    • Remove the 3 strips of black tape as shown to reveal connections 2 and 3.
    • Pull the wiring for each away from the connections to remove.
  14. Panasonic Toughbook CF-29 Touchscreen Replacement: stap 14, afbeelding 1 van 1
    • The 4th connection is already visible.
    • Depending on your model it might not be plugged into anything. If it is, remove it the same way the other 3 connections were removed.
  15. Panasonic Toughbook CF-29 Touchscreen Replacement: stap 15, afbeelding 1 van 2 Panasonic Toughbook CF-29 Touchscreen Replacement: stap 15, afbeelding 2 van 2
    • Using a plastic opening tool, lift the screen as shown from the case and pull free.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Dylan Bloom
373 Reputatie
4 handleidingen geschreven
Cal Poly, Team 27-93, Amido Spring 2010 Lid van Cal Poly, Team 27-93, Amido Spring 2010
CPSU-AMIDO-S10S27G93
4 Leden
26 handleidingen geschreven
Één opmerking
This guide is good for replacing the LCD screen, but it is not complete for the touchscreen panel, which requires some more delicate and precise steps. I think the title of the guide needs to be changed.
Thanks
Alessandro Cervelli - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 14
Altijd: 17,080
