Ga door naar hoofdinhoud
Panasonic Toughbook CF-29 Motherboard Replacement
Wat je nodig hebt
  1. Panasonic Toughbook CF-29 Motherboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Locate the bay door for the battery on the left side of the laptop.
  2. Panasonic Toughbook CF-29 Motherboard Replacement: stap 2, afbeelding 1 van 2 Panasonic Toughbook CF-29 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Slide the latch to the right and then down to unlock it.
    • Pull out the battery.
  3. Panasonic Toughbook CF-29 Motherboard Replacement, Hard Drive: stap 3, afbeelding 1 van 1
    • Locate the door for the hard drive on the right side of the laptop
  4. Panasonic Toughbook CF-29 Motherboard Replacement: stap 4, afbeelding 1 van 2 Panasonic Toughbook CF-29 Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Push and slide the latch up to open the hard drive door.
    • Pull out the hard drive.
  5. Panasonic Toughbook CF-29 Motherboard Replacement, Optical Drive: stap 5, afbeelding 1 van 1
    • Flip the device upside down with the handle facing away from you.
    • Open the optical drive bay by sliding its latch to the right.
    • Locate optical drive release mechanism on the bottom of the laptop.
  6. Panasonic Toughbook CF-29 Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Slide the latch cover to the right.
  7. Panasonic Toughbook CF-29 Motherboard Replacement: stap 7, afbeelding 1 van 2 Panasonic Toughbook CF-29 Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Push the exposed switch to the left to eject the optical drive.
  8. Panasonic Toughbook CF-29 Motherboard Replacement, Back Cover: stap 8, afbeelding 1 van 1
    • Begin by turning the laptop upside down with the handle towards you.
    • Use a Phillips size 0 screwdriver to remove the 4 screws holding down the ram cover.
  9. Panasonic Toughbook CF-29 Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Remove the panel and set it aside.
    • Use a Phillips size 0 screwdriver to remove these 8 small screws.
  10. Panasonic Toughbook CF-29 Motherboard Replacement: stap 10, afbeelding 1 van 1
    • Use a Phillips size 1 screwdriver to remove the remaining 8 screws.
  11. Panasonic Toughbook CF-29 Motherboard Replacement: stap 11, afbeelding 1 van 2 Panasonic Toughbook CF-29 Motherboard Replacement: stap 11, afbeelding 2 van 2
    • Use a plastic opening tool to release, but NOT remove, the back cover because it is sealed with adhesive.
  12. Panasonic Toughbook CF-29 Motherboard Replacement: stap 12, afbeelding 1 van 1
    • Be careful when lifting the cover as you may damage some connections.
    • Slowly lift the cover so that you can disconnect the red and white wires connecting the speaker to the sound card.
  13. Panasonic Toughbook CF-29 Motherboard Replacement: stap 13, afbeelding 1 van 1
    • Now the back cover should be off and you can access the inside of the casing.
  14. Panasonic Toughbook CF-29 Motherboard Replacement, Wireless Card: stap 14, afbeelding 1 van 1
    • Remove the black and white wires attached to the wireless card by simply pulling up.
  15. Panasonic Toughbook CF-29 Motherboard Replacement: stap 15, afbeelding 1 van 1
    • Peel back the black cover to expose the clips holding in the wireless card.
  16. Panasonic Toughbook CF-29 Motherboard Replacement: stap 16, afbeelding 1 van 1
    • Using a pair of plastic opening tools, push the two metal tabs away from the card.
  17. Panasonic Toughbook CF-29 Motherboard Replacement: stap 17, afbeelding 1 van 2 Panasonic Toughbook CF-29 Motherboard Replacement: stap 17, afbeelding 2 van 2
    • The wireless card should now easily disengage from the motherboard.
    • Pull the card horizontally away from you to remove it from its housing.
  18. Panasonic Toughbook CF-29 Motherboard Replacement, Motherboard: stap 18, afbeelding 1 van 2 Panasonic Toughbook CF-29 Motherboard Replacement, Motherboard: stap 18, afbeelding 2 van 2
    • Unplug 3 cables
    • Lift up on brown tab to release cable
    • Pull cable up and out
  19. Panasonic Toughbook CF-29 Motherboard Replacement: stap 19, afbeelding 1 van 2 Panasonic Toughbook CF-29 Motherboard Replacement: stap 19, afbeelding 2 van 2
    • Remove 2 long screws indicated with red circles
    • Remove the remaining screws indicated in blue
  20. Panasonic Toughbook CF-29 Motherboard Replacement: stap 20, afbeelding 1 van 1
    • On the back of the unit, unscrew the three screws surrounding the serial port.
  21. Panasonic Toughbook CF-29 Motherboard Replacement: stap 21, afbeelding 1 van 1
    • Lift the motherboard as shown, pull towards you and then up.
    • Do not yet try to fully remove the motherboard or you may destroy the connections
  22. Panasonic Toughbook CF-29 Motherboard Replacement: stap 22, afbeelding 1 van 1
    • Detach the white ribbon cable, the white cluster connector, and the ribbon cable right next to the cluster
  23. Panasonic Toughbook CF-29 Motherboard Replacement: stap 23, afbeelding 1 van 2 Panasonic Toughbook CF-29 Motherboard Replacement: stap 23, afbeelding 2 van 2
    • Remove the board.
Conclusie
8 andere personen hebben deze handleiding voltooid.
Dylan Bloom
373 Reputatie
4 handleidingen geschreven
Cal Poly, Team 27-93, Amido Spring 2010 Lid van Cal Poly, Team 27-93, Amido Spring 2010
CPSU-AMIDO-S10S27G93
4 Leden
26 handleidingen geschreven
4 opmerkingen
what about spare parts? is it possible cange MOBO and CPU?  in order to upgrade the thoughbook?
Concetto Salierno - Antwoord
I think y'all missed a step.
Gemini - Antwoord
Où acheter la carte mère?
MERCI
Pascal Cohu - Antwoord
Sur Google, recherchez "DL3UP1396AAA Panasonic CF-29 System Board" (à rechercher sans les guillemets), vous aurez quelques résultats (j'ai vu au moins 2 sites qui la propose à la vente), par contre, elle est cher.
Autre recherche possible : "DL3UP1396BAA Panasonic CF-29 System Board", je ne connais pas la différence entre ces variantes
Autre recherche possible : "DL3U11213FAA Panasonic CF-29 System Board", je ne connais pas la différence entre ces variantes
Brendan -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 27
Altijd: 25,808
