Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
This guide will disassemble the device in the most concise way possible to get to the CD Tray Cover and give precise directions on how to put a new one in.
Wat je nodig hebt
Using a Phillips screwdriver, remove the eight 9.5 mm screws on the left and right sides of the device.
This step deals with the indicated area of the device.
Lift the indicated tabs out until the restraint looks like the final picture.
Gently pull on the cord until it comes free of the attachment.
The top section of the device should now be free of the body. Place it aside in a safe place.
Using tweezers or fingers, lift gently on the tab indicated to free the front from the body of the device.
Rotate device 180 degrees and repeat for other side.
Rotate the front slightly forward to keep the tabs from re-engaging on their hooks.
Remove the two 11.5 mm screws indicated and set aside in a safe place.
