Ga door naar hoofdinhoud
Panasonic RQ-2102 Holding Handle Replacement
Wat je nodig hebt
  1. Panasonic RQ-2102 Holding Handle Replacement, Holding Handle: stap 1, afbeelding 1 van 3 Panasonic RQ-2102 Holding Handle Replacement, Holding Handle: stap 1, afbeelding 2 van 3 Panasonic RQ-2102 Holding Handle Replacement, Holding Handle: stap 1, afbeelding 3 van 3
    • Remove the three M5-0.8 x 12 mm Phillips #0 screws from the back of the device body.
    • There are two more screws inside the battery compartment. Remove those as well.
    • Cautiously remove the back of the device body. Be sure not to damage the cord that connects the two sides.
    • All of the screws are the same size.
  2. Panasonic RQ-2102 Holding Handle Replacement: stap 2, afbeelding 1 van 2 Panasonic RQ-2102 Holding Handle Replacement: stap 2, afbeelding 2 van 2
    • Carefully remove the handle. Make sure the handle catches on each side are intact.
    • Replace the old handle with the new handle.
    • Remember, if the handle catches are broken, the device must be replaced.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 22
Altijd: 556
