Ga door naar hoofdinhoud
Panasonic RQ-2102 Cassette Holder Spring Replacement
Wat je nodig hebt
  1. Panasonic RQ-2102 Cassette Holder Spring Replacement, Cassette Holder Spring: stap 1, afbeelding 1 van 3 Panasonic RQ-2102 Cassette Holder Spring Replacement, Cassette Holder Spring: stap 1, afbeelding 2 van 3 Panasonic RQ-2102 Cassette Holder Spring Replacement, Cassette Holder Spring: stap 1, afbeelding 3 van 3
    • Remove the three screws from the back of the device body.
    • Remove both screws from the battery compartment.
    • Remove the back of the device.
    • All screws in the body of this device are the same size.
    • When pulling apart the device, both sides are connected by a cord that could be damaged if care is not taken.
  2. Panasonic RQ-2102 Cassette Holder Spring Replacement: stap 2, afbeelding 1 van 3 Panasonic RQ-2102 Cassette Holder Spring Replacement: stap 2, afbeelding 2 van 3 Panasonic RQ-2102 Cassette Holder Spring Replacement: stap 2, afbeelding 3 van 3
    • Make sure the brass colored spring by the cassette door is in the correct position.
    • Remove the screw that holds the spring if broken.
    • Remove the spring from the device.
  3. Panasonic RQ-2102 Cassette Holder Spring Replacement: stap 3, afbeelding 1 van 2 Panasonic RQ-2102 Cassette Holder Spring Replacement: stap 3, afbeelding 2 van 2
    • Replace the old spring with the new spring, making sure that it is installed in the correct position.
    • Insert the screw back into position, ensuring that it holds the spring.
    • If the spring is loose, tighten the screw.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 12
Altijd: 995
