Inleiding
A guide to removing the lens assembly on the camcorder.
Gereedschap
Onderdelen
Geen onderdelen nodig.
Using a plastic opening tool, remove the record/playback and record/power control knobs from the camcorder.
Rotate the camcorder so that the tape compartment is facing you. Remove the single 4.5mm black screw, which is above the hook for the hand strap.
It may help you during this step to undo the strap on one end.
Next, rotate the camcorder so that the lens is facing you. Remove the single 4.5mm black screw from the front panel.
Now, from where the front cover used to be, remove the two 4.5mm black screws from the LCD side of the camera.
Place a plastic opening tool under the bottom of the blue panel beneath the camcorder. Using two tools may be useful, if difficult.
Move the plastic opening tool up the side of the camcorder as shown, carefully separating the LCD panel from the rest of the camcorder.
With the blue LCD panel free from the rest of the camcorder, remove the panel from the camcorder.
Using #00 phillips screwdriver, remove two 4.5mm black screws holding lens in place.
