Ga door naar hoofdinhoud
Inleiding
How to fix squeaky water flow
Onderdelen
Geen onderdelen opgegeven.
  1. Warning: Bevore working at it unplug the power. Here you can see the plastic tube from where the water comes out. it is clipped in a clear plastic shape. Open the clips and pull Shake it a litlle so the tube can get out here.
    • Warning: Bevore working at it unplug the power. Here you can see the plastic tube from where the water comes out. it is clipped in a clear plastic shape. Open the clips and pull
    • Shake it a litlle so the tube can get out here.
    • This clear plastic is fragile,
    • be careful with it or the clipse may break.
  2. More pictures, look. you can clean it with citric acid. you can clean it with citric acid.
    • More pictures, look.
    • you can clean it with citric acid.
  3. MacBook-reparatiesets voor batterijen
    Vanaf $69.99
    Buy Now
    Vanaf $69.99
    Buy Now
  4. How to open. First remove two PH2 screws left and right. PULL the complete display. Shake it a little because the flap of the ice-crusher could be frosted. Now pull it downwards. Now turn around and you see the plastic from the lever.
    • How to open. First remove two PH2 screws left and right.
    • PULL the complete display. Shake it a little because the flap of the ice-crusher could be frosted.
    • Now pull it downwards. Now turn around and you see the plastic from the lever.
  5. This is the backside: The quadratic black rubber part is a motorized flap of the ice-crusher, be careful with it, there are fragile springs, dont loose them.
    • This is the backside: The quadratic black rubber part is a motorized flap of the ice-crusher, be careful with it, there are fragile springs, dont loose them.
    • Now spray some SILICONE_SPRAY on the moving parts, i made some red circles for it. Just a little bit, also on the springs.
    • TRY, move it, now the noise should gone, whiole moving it.
    • Thats it, reassemble it, be careful with the notches and clipse.
    • done. :)
Conclusie
easy
Met dank aan deze vertalers:
100%
Schwarzstein helpt ons de wereld te herstellen! Wil je bijdragen?
Begin met vertalen ›
Schwarzstein
2.334 Reputatie
14 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 1
Afgelopen 30 Dagen: 18
Altijd: 617
