Ga door naar hoofdinhoud
Panasonic Lumix DMC-ZS8 LCD Display Screen Replacement
Wat je nodig hebt
  1. Panasonic Lumix DMC-ZS8 LCD Display Screen Replacement, Removing External Screws: stap 1, afbeelding 1 van 3 Panasonic Lumix DMC-ZS8 LCD Display Screen Replacement, Removing External Screws: stap 1, afbeelding 2 van 3 Panasonic Lumix DMC-ZS8 LCD Display Screen Replacement, Removing External Screws: stap 1, afbeelding 3 van 3
    • Remove Battery and Strap from unit.
    • Remove the 3 screws from the bottom
    • Remove screws from both sides of unit (4 screws total)
  2. Panasonic Lumix DMC-ZS8 LCD Display Screen Replacement, Removing the Side Panels: stap 2, afbeelding 1 van 2 Panasonic Lumix DMC-ZS8 LCD Display Screen Replacement, Removing the Side Panels: stap 2, afbeelding 2 van 2
    • Remove both side panels from unit. You can pry them off with your finger nail or a spudger
  3. Panasonic Lumix DMC-ZS8 LCD Display Screen Replacement, Removing the Rear Cover: stap 3, afbeelding 1 van 2 Panasonic Lumix DMC-ZS8 LCD Display Screen Replacement, Removing the Rear Cover: stap 3, afbeelding 2 van 2
    • Pry off rear cover. Make sure LCD remains in place.
    • There is a thin film of adhesive attaching the LCD to the rear cover. It releases easily with a little pressure. If necessary hold the LCD in place while removing the rear cover.
  4. Panasonic Lumix DMC-ZS8 LCD Display Screen Replacement, Removing the LCD: stap 4, afbeelding 1 van 3 Panasonic Lumix DMC-ZS8 LCD Display Screen Replacement, Removing the LCD: stap 4, afbeelding 2 van 3 Panasonic Lumix DMC-ZS8 LCD Display Screen Replacement, Removing the LCD: stap 4, afbeelding 3 van 3
    • Release the Ziff clamp holding the LCD cable. 1st photo shows clamp in closed position.
    • You can use a spudger to release the clamp. You can also use your finger nail, but be careful it is very fragile.
    • Remove the LCD Flex from the clamp
  5. Panasonic Lumix DMC-ZS8 LCD Display Screen Replacement: stap 5, afbeelding 1 van 3 Panasonic Lumix DMC-ZS8 LCD Display Screen Replacement: stap 5, afbeelding 2 van 3 Panasonic Lumix DMC-ZS8 LCD Display Screen Replacement: stap 5, afbeelding 3 van 3
    • You may need to pry off the window plate of your old screen if the new screen doesn't have one.
    • If required: Remove the window plate from your old screen if your new LCD doesn't have one. Save this part for re-install.
  6. Panasonic Lumix DMC-ZS8 LCD Display Screen Replacement, Clean up Window Plate and Reassemble: stap 6, afbeelding 1 van 2 Panasonic Lumix DMC-ZS8 LCD Display Screen Replacement, Clean up Window Plate and Reassemble: stap 6, afbeelding 2 van 2
    • If your new LCD does not come with a window plate: Tape your old window plate in place as shown in the photo. Make sure it lines up properly and fits into the grooves. This makes re-assembly much easier.
    • If necessary clean the window plate and LCD with a micro fiber dry cloth. Make sure there is no debris or dust before you re-install. DO NOT use any liquids.
    • Now just reverse the steps to re-assemble your camera with the new screen.
Conclusie
Sales Cameraparts4you
3.150 Reputatie
20 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 11
Altijd: 329
