Inleiding
In case your LCD screen is unresponsive, cracked, or otherwise damaged/broken, you can follow this guide to remove or replace it with a functioning LCD screen of the same model.
Before you replace your LCD screen, take a look at this Troubleshooting Guide to see if there is a simpler solution to your problem. Before you begin, make sure to turn the camera off and remove the battery.
Wat je nodig hebt
Remove the six 4mm screws located on the side and bottom of the camera casing using a Phillips #000 screwdriver.
Unscrew the four 3mm screws holding the LCD screen hinge in place using a Phillips #000 screwdriver.
