Ga door naar hoofdinhoud
Panasonic Lumix DMC-ZS3 Lens Replacement
Wat je nodig hebt
  1. Panasonic Lumix DMC-ZS3 Lens Replacement, Back Cover: stap 1, afbeelding 1 van 3 Panasonic Lumix DMC-ZS3 Lens Replacement, Back Cover: stap 1, afbeelding 2 van 3 Panasonic Lumix DMC-ZS3 Lens Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Remove the following eleven screws securing the covers to the ZS3
    • Eleven 3 mm Phillips screws
    • Using too much pressure when removing the screws may strip the screws and complicate screw removal at a later time.
  2. Panasonic Lumix DMC-ZS3 Lens Replacement: stap 2, afbeelding 1 van 2 Panasonic Lumix DMC-ZS3 Lens Replacement: stap 2, afbeelding 2 van 2
    • Use the flat end of a spudger to pry apart the back cover from the rest of the unit as shown.
    • Be sure to carefully and slowly lift the back cover. Forcefully lifting the back cover and fully separating it at this point may ruin internal connections.
  3. Panasonic Lumix DMC-ZS3 Lens Replacement: stap 3, afbeelding 1 van 2 Panasonic Lumix DMC-ZS3 Lens Replacement: stap 3, afbeelding 2 van 2
    • Using your fingernail or a spudger, flip up the ZIF locking flap on the two LCD ribbon cable sockets that connect the back cover to the rest of the unit.
    • Be sure you are opening the locking tab, not pulling against the socket mounted to the board.
  4. Panasonic Lumix DMC-ZS3 Lens Replacement: stap 4, afbeelding 1 van 1
    • Remove the two LCD board ribbon cables out of their sockets.
  5. Panasonic Lumix DMC-ZS3 Lens Replacement, Lens: stap 5, afbeelding 1 van 1
    • Remove the three 3 mm black screws that surround the lens using a Phillips #00 screwdriver.
  6. Panasonic Lumix DMC-ZS3 Lens Replacement: stap 6, afbeelding 1 van 3 Panasonic Lumix DMC-ZS3 Lens Replacement: stap 6, afbeelding 2 van 3 Panasonic Lumix DMC-ZS3 Lens Replacement: stap 6, afbeelding 3 van 3
    • Flip up the locking flaps on the two LCD ribbon cable sockets with the spudger.
    • The LCD ribbon cables connect the back cover to the rest of the unit.
    • Use the spudger to disconnect the LCD ribbons.
  7. Panasonic Lumix DMC-ZS3 Lens Replacement: stap 7, afbeelding 1 van 3 Panasonic Lumix DMC-ZS3 Lens Replacement: stap 7, afbeelding 2 van 3 Panasonic Lumix DMC-ZS3 Lens Replacement: stap 7, afbeelding 3 van 3
    • Use your fingers or a spudger to gently remove the lens mechanism from the rest of the camera.
    • Excessive force may damage the camera. Be sure to lift the lens slowly and carefully to avoid damage to other parts.
    • Unlock lens mechanism located on the bottom of the device using your fingers.
Conclusie
Kellen Ericson
18 Reputatie
1 Handleiding geschreven
Cal Poly, Team 13-60, Johann Spring 2013 Lid van Cal Poly, Team 13-60, Johann Spring 2013
CPSU-JOHANN-S13S13G60
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 69
Altijd: 3,269
