Ga door naar hoofdinhoud
Panasonic Lumix DMC-ZS25 Screen Replacement
Wat je nodig hebt
  1. Panasonic Lumix DMC-ZS25  Screen Replacement, Screen: stap 1, afbeelding 1 van 3 Panasonic Lumix DMC-ZS25  Screen Replacement, Screen: stap 1, afbeelding 2 van 3 Panasonic Lumix DMC-ZS25  Screen Replacement, Screen: stap 1, afbeelding 3 van 3
    • Open the four 3.40 mm screws from the right and left sides of your Panasonic Lumix Camera.
    • Remove the two 2.60 mm screws located next to the battery.
  2. Panasonic Lumix DMC-ZS25  Screen Replacement: stap 2, afbeelding 1 van 1
    • Use the plastic opening tool to open the outer cover of your device from the HDMI port.
    • Open it carefully to avoid breaking the cover.
  3. Panasonic Lumix DMC-ZS25  Screen Replacement: stap 3, afbeelding 1 van 3 Panasonic Lumix DMC-ZS25  Screen Replacement: stap 3, afbeelding 2 van 3 Panasonic Lumix DMC-ZS25  Screen Replacement: stap 3, afbeelding 3 van 3
    • Use a spudger to carefully detach the ribbon cable without breaking it.
  4. Panasonic Lumix DMC-ZS25  Screen Replacement: stap 4, afbeelding 1 van 1
    • Use the plastic opening tool to lift and remove the buttons board as shown.
  5. Panasonic Lumix DMC-ZS25  Screen Replacement: stap 5, afbeelding 1 van 2 Panasonic Lumix DMC-ZS25  Screen Replacement: stap 5, afbeelding 2 van 2
    • Carefully lift the screen using the plastic opening tool as shown.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Abbas Khan
482 Reputatie
4 handleidingen geschreven
USF Tampa, Team 9-5, Brown Winter 2015 Lid van USF Tampa, Team 9-5, Brown Winter 2015
USFT-BROWN-W15S9G5
3 Leden
7 handleidingen geschreven
Één opmerking
- Of the two 2.60 mm screws on the bottom of the camera, only the one closest to the back needs to be removed.
- The correct screwdriver is JIS Type S #00. A Phillips driver can ruin the screws.
- The screen shown in step 5 consists of two parts: the LCD and a frame. The replacement LCD that I ordered came without the frame, so a little more disassembly was required, including a bit of delicate soldering: the narrow ribbon cable is really two cables, soldered together. The solder joints are hidden under the piece of black electric tape at the end.
nasorenga - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 4,364
