Ga door naar hoofdinhoud
Inleiding
Step by step guide to replacing your damaged LCD Display
Gereedschap
Geen gereedschap opgegeven.
Onderdelen
  1. Remove the battery and memory card from the unit Remove 6 (0.3mm) screws from the sides of the unit Remove 5 (0.3mm) screws from the bottom of the unit
    • Remove the battery and memory card from the unit
    • Remove 6 (0.3mm) screws from the sides of the unit
    • Remove 5 (0.3mm) screws from the bottom of the unit
  2. Lift up slightly the rear cover. Do not remove rear cover yet. It is still attached to the Main PCB.
    • Lift up slightly the rear cover.
    • Do not remove rear cover yet. It is still attached to the Main PCB.
    • Flip up the cable clamps using a spudger or other device. Careful not to break the clamps. Release flex cables and remove back cover.
  3. Release the 3 metal clips from the rear cover and remove the LCD Release the 3 metal clips from the rear cover and remove the LCD Release the 3 metal clips from the rear cover and remove the LCD
    • Release the 3 metal clips from the rear cover and remove the LCD
Conclusie
Sales Cameraparts4you
2.877 Reputatie
20 handleidingen geschreven
0 Opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 223
