Ga door naar hoofdinhoud
Panasonic Lumix DMC-TZ5 lcd screen replacement
Wat je nodig hebt
  1. Panasonic Lumix DMC-TZ5 lcd screen replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Remove the battery and memory card from the device.
  2. Panasonic Lumix DMC-TZ5 lcd screen replacement: stap 2, afbeelding 1 van 1
    • Remove 4 screws from the right side of the camera.
    • There are two 3.4mm screws at the top.
    • There are two 2.2mm screws at the bottom.
  3. Panasonic Lumix DMC-TZ5 lcd screen replacement: stap 3, afbeelding 1 van 1
    • Remove the single 3.4mm screw on the left side of the camera.
  4. Panasonic Lumix DMC-TZ5 lcd screen replacement: stap 4, afbeelding 1 van 1
    • Remove 5 screws from the base of the camera.
    • There are two 2.2mm screws next to the battery compartment.
    • There are three 4mm screws around the tripod mount.
  5. Panasonic Lumix DMC-TZ5 lcd screen replacement: stap 5, afbeelding 1 van 1
    • Slowly slide the back cover away from the device
    • The back casing is held in place by two ribbon cables. Do not pull the back cover too far from the camera.
  6. Panasonic Lumix DMC-TZ5 lcd screen replacement: stap 6, afbeelding 1 van 2 Panasonic Lumix DMC-TZ5 lcd screen replacement: stap 6, afbeelding 2 van 2
    • Detach both ribbon cables using a spudger.
    • Use the tip of the spudger to lift the black clip upward, unlocking the ribbon cable.
  7. Panasonic Lumix DMC-TZ5 lcd screen replacement: stap 7, afbeelding 1 van 1
    • Remove the back casing from the camera.
  8. Panasonic Lumix DMC-TZ5 lcd screen replacement, LCD: stap 8, afbeelding 1 van 2 Panasonic Lumix DMC-TZ5 lcd screen replacement, LCD: stap 8, afbeelding 2 van 2
    • Use a spudger to release the 3 clips between the LCD case and housing.
    • Put the tip of the spudger in the gap between the clip and housing, then lift up gently to unclip.
    • Gently lift the LCD from the case, making sure none of the 3 clips reattach.
Conclusie
14 andere personen hebben deze handleiding voltooid.
Ben Canfield
409 Reputatie
3 handleidingen geschreven
Cal Poly, Team 9-21, Regan Fall 2010 Lid van Cal Poly, Team 9-21, Regan Fall 2010
CPSU-REGAN-F10S9G21
4 Leden
14 handleidingen geschreven
4 opmerkingen
If you want to go the easy route as shown above, then buy the LCD/backlight kit from Panasonic. Otherwise, if you buy the bare LCD (99% of online retails sell the bare LCD, no kit) then you have a 30 minute install on your hands. The bare LCD is nested within a metal/plastic frame which is nested in the backlight frame which is where the above tutorial ends. You'll need dextrous fingers to get the frames off of each other or else you risk bending the frame. Btw, DO NOT remove any tape. Removal of tape is not necessary and may cause visual or circuitry problems.
tonnage - Antwoord
This guide also works for the TZ7, slightly different screw arrangement but otherwise the process is identical.
I had a bare LCD kit so the last step was trickier than the guide shows, the note above is accurate, the extra frames are quite flimsy so care is required. But I am no watchmaker and I managed it ok; it is just a bit slower than the guide shows.
cotsweb - Antwoord
Totally agree with the above notes, however the circuit tapes on mine were under the adhesive tape on the backlight, meaning this had to be lifted in the one area to release the circuit tape off the LCD glass. Make a good note of the orientation of the LCD / Backlight glass parts in the frame as there is a metal frame, plastic surround, gasket and the two glass parts all to get back together the right way up and round. Lay it out and make a note if needed as you take it apart and it should work ok - I did find pushing the 2 conductor parts back into the circuit board quite tricky.
Jon Worsfold -
Guys,
Thank you SO MUCH !
It is really great to be able to rely on these tutorials !
I have just replaced the screen of my beloved TZ5 in 30mn (being extra cautious).
Keep it up !
/Patrice
Patrice Touboul - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 67
Altijd: 35,166
