Ga door naar hoofdinhoud
Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Panasonic Lumix DMC-TZ35 LCD Replacement
Wat je nodig hebt
  1. Panasonic Lumix DMC-TZ35 LCD Replacement, Removing the back - 1: stap 1, afbeelding 1 van 2 Panasonic Lumix DMC-TZ35 LCD Replacement, Removing the back - 1: stap 1, afbeelding 2 van 2
    • Remove 2 screws on the right hand side of the case.
    • Remove 2 screws on the left hand side of the case.
  2. Panasonic Lumix DMC-TZ35 LCD Replacement, Removing the back - 2: stap 2, afbeelding 1 van 2 Panasonic Lumix DMC-TZ35 LCD Replacement, Removing the back - 2: stap 2, afbeelding 2 van 2
    • Remove 2 screws on the bottom of the case, adjacent to the tripod mount. Note that these screws are slightly shorter than the previous ones and so should be kept separate.
    • Ease off the case back. You can help it off by inserting a spudger in the crack on all sides to ease it, especially either side of any points where it seems reluctant to come.
  3. Panasonic Lumix DMC-TZ35 LCD Replacement, Removing the buttons board: stap 3, afbeelding 1 van 2 Panasonic Lumix DMC-TZ35 LCD Replacement, Removing the buttons board: stap 3, afbeelding 2 van 2
    • Gently lift the locking bar on the LCD ribbon, then ease the ribbon out of the socket.
    • Lift the buttons board by inserting a spudger under the bottom right hand edge. This will detach it from a connector beneath.
  4. Panasonic Lumix DMC-TZ35 LCD Replacement, Removing the LCD: stap 4, afbeelding 1 van 1
    • Release a clip on the left hand side of the LCD and hence lift the LCD out.
Conclusie
Philip Le Riche
30.083 Reputatie
47 handleidingen geschreven
Restart Project Lid van Restart Project
Community
18 Leden
504 handleidingen geschreven
2 opmerkingen
Theres a few missing steps. The old LCD screen will need removing from the container that holds it in and the new replacement LCD screen will need to be fitted inside it. Also, there are 2 connections on the LCD ribbon. One goes in as described. On the old screen carefully pull apart the 2nd connection between the screen and the camera. The new LCD screen will then need 2 dabs of solder on the 2nd connection between the new screens ribbon cable and the one within the camera. Its pretty straightforward but the screen will not work without both connectors fitted properly.
Anthony Todd - Antwoord
My camera was an Panasonic DMC-TZ70, but the difference was not big. The job was easy.
John Vonk - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 2,320
