Ga door naar hoofdinhoud
Panasonic Lumix DMC-GF2 Front Cover Replacement
Wat je nodig hebt
  1. Panasonic Lumix DMC-GF2 Front Cover Replacement, Battery: stap 1, afbeelding 1 van 1
    • On the bottom of the camera, use your finger to push the lock button to the open position which will cause the hinged door to swing open.
  2. Panasonic Lumix DMC-GF2 Front Cover Replacement: stap 2, afbeelding 1 van 2 Panasonic Lumix DMC-GF2 Front Cover Replacement: stap 2, afbeelding 2 van 2
    • Push the small black tab that holds the battery with your finger to release the battery.
    • Use your fingers to pull the battery out of the camera.
  3. Panasonic Lumix DMC-GF2 Front Cover Replacement, Front Cover: stap 3, afbeelding 1 van 3 Panasonic Lumix DMC-GF2 Front Cover Replacement, Front Cover: stap 3, afbeelding 2 van 3 Panasonic Lumix DMC-GF2 Front Cover Replacement, Front Cover: stap 3, afbeelding 3 van 3
    • Using a Philips #00 screwdriver, remove six 2.69 mm screws located on the two short sides and on the bottom of the camera.
    • To loosen a screw, turn the screwdriver to the left. To tighten a screw, turn the screwdriver to the right.
  4. Panasonic Lumix DMC-GF2 Front Cover Replacement: stap 4, afbeelding 1 van 1
    • Using a Phillips #00 screwdriver, remove four black 2.69 mm screws from the front of the camera.
  5. Panasonic Lumix DMC-GF2 Front Cover Replacement: stap 5, afbeelding 1 van 1
    • Using your hand, gently lift up the front cover and separate it from the camera.
Conclusie
Nicole Gerlach
218 Reputatie
1 Handleiding geschreven
Baylor, Team 5-9, Williams Fall 2016 Lid van Baylor, Team 5-9, Williams Fall 2016
BU-WILLIAMS-F16S5G9
3 Leden
11 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 14
Altijd: 1,039
