Ga door naar hoofdinhoud
Panasonic Lumix DMC-GF2 Back Cover Replacement
Wat je nodig hebt
  1. Panasonic Lumix DMC-GF2 Back Cover Replacement, Battery: stap 1, afbeelding 1 van 1
    • On the bottom of the camera, use your finger to push the lock button to the open position which will cause the hinged door to swing open.
  2. Panasonic Lumix DMC-GF2 Back Cover Replacement: stap 2, afbeelding 1 van 2 Panasonic Lumix DMC-GF2 Back Cover Replacement: stap 2, afbeelding 2 van 2
    • Push the small black tab that holds the battery with your finger to release the battery.
    • Use your fingers to pull the battery out of the camera.
  3. Panasonic Lumix DMC-GF2 Back Cover Replacement, Back Cover: stap 3, afbeelding 1 van 3 Panasonic Lumix DMC-GF2 Back Cover Replacement, Back Cover: stap 3, afbeelding 2 van 3 Panasonic Lumix DMC-GF2 Back Cover Replacement, Back Cover: stap 3, afbeelding 3 van 3
    • Using a Phillips #00 screwdriver, remove six 2.69mm, silver screws located on the two short sides of the camera and the bottom side.
  4. Panasonic Lumix DMC-GF2 Back Cover Replacement: stap 4, afbeelding 1 van 3 Panasonic Lumix DMC-GF2 Back Cover Replacement: stap 4, afbeelding 2 van 3 Panasonic Lumix DMC-GF2 Back Cover Replacement: stap 4, afbeelding 3 van 3
    • Gently lift up the back cover to access the ZIF connectors for the blue and yellow ribbons.
    • To unlock the ZIF connectors, gently push the black portion of the lock from a flat position to an upright position using a spudger.
    • Take caution not to rip the ribbons out of the ZIF connectors when lifting the back panel.
  5. Panasonic Lumix DMC-GF2 Back Cover Replacement: stap 5, afbeelding 1 van 1
    • Gently push the blue and yellow ribbons out of the unlocked ZIF connectors using your fingers.
  6. Panasonic Lumix DMC-GF2 Back Cover Replacement: stap 6, afbeelding 1 van 1
    • Using a Phillips #00 screwdriver, remove the 3.5 mm silver screw from the upper left hand corner of the back cover.
  7. Panasonic Lumix DMC-GF2 Back Cover Replacement: stap 7, afbeelding 1 van 1
    • Using a spudger, lift up and remove the plastic cover piece from the back cover.
    • Plastic cover may fall off without prying.
  8. Panasonic Lumix DMC-GF2 Back Cover Replacement: stap 8, afbeelding 1 van 1
    • Using a Phillips #00 screwdriver, remove the 2.69 mm silver screw located beneath the plastic piece that was previously removed.
  9. Panasonic Lumix DMC-GF2 Back Cover Replacement: stap 9, afbeelding 1 van 1
    • Using a spudger, lift up and separate the heavier metal cover from the light, plastic back cover.
    • Metal cover may fall off without prying.
Conclusie
Kingsley East
462 Reputatie
4 handleidingen geschreven
Baylor, Team 5-9, Williams Fall 2016 Lid van Baylor, Team 5-9, Williams Fall 2016
BU-WILLIAMS-F16S5G9
3 Leden
11 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 17
Altijd: 1,079
