Inleiding
If the LCD panel has usability inhibiting number of dead pixels, or if the backlight comes on but no image is shown (or vice versa), then use the following guide to replace the LCD unit.
Wat je nodig hebt
Unlock and open the battery compartment on the bottom of the camera.
Remove both the battery and SD card.
6 andere personen hebben deze handleiding voltooid.
5 opmerkingen
Hello, after owning my camera for 4 years, I dropped my camera and the screen went black. On and off switch works and the camera still makes shutter noises. I tried pressing the fn5 button thinking it was on the view finder but it did not work. Any help? thanks
Hi. I, having the same issue. LCD and View finder only show black screen. Camera does work and makes shutter noise (and saves pictures on SD kard) Did you solve your Problem?
Wonderful. I actually need to change the LCD display control main circuit board. Is that the piece of circuity stuck at the back of the LCD?
Thanks!
Really greatful for this post. G7 fixed!
Screen was loose, now fixed in 20 minutes, going to step 7. Yay! Rockstars.
