Ga door naar hoofdinhoud
Panasonic Lumix DMC-FZ1000 Lens Replacement
Wat je nodig hebt
  1. Panasonic Lumix DMC-FZ1000 Lens Replacement, Battery: stap 1, afbeelding 1 van 3 Panasonic Lumix DMC-FZ1000 Lens Replacement, Battery: stap 1, afbeelding 2 van 3 Panasonic Lumix DMC-FZ1000 Lens Replacement, Battery: stap 1, afbeelding 3 van 3
    • Slide the switch on the bottom of your camera from the right (LOCK) to the left (OPEN).
    • The battery door will swing open.
  2. Panasonic Lumix DMC-FZ1000 Lens Replacement: stap 2, afbeelding 1 van 2 Panasonic Lumix DMC-FZ1000 Lens Replacement: stap 2, afbeelding 2 van 2
    • Pull down on the lever that holds the battery.
    • The battery will pop out of its casing.
  3. Panasonic Lumix DMC-FZ1000 Lens Replacement: stap 3, afbeelding 1 van 1
    • Pull out the battery.
  4. Panasonic Lumix DMC-FZ1000 Lens Replacement, Motherboard: stap 4, afbeelding 1 van 3 Panasonic Lumix DMC-FZ1000 Lens Replacement, Motherboard: stap 4, afbeelding 2 van 3 Panasonic Lumix DMC-FZ1000 Lens Replacement, Motherboard: stap 4, afbeelding 3 van 3
    • Push in on the SD card inside the battery housing.
    • The SD card will pop out.
    • Pull out the SD card.
    • Close the battery housing door.
  5. Panasonic Lumix DMC-FZ1000 Lens Replacement: stap 5, afbeelding 1 van 3 Panasonic Lumix DMC-FZ1000 Lens Replacement: stap 5, afbeelding 2 van 3 Panasonic Lumix DMC-FZ1000 Lens Replacement: stap 5, afbeelding 3 van 3
    • Remove the two 5.2 mm Phillips #00 screws that are 1) below the label and 2) above the tripod mount hole on the bottom of the camera.
    • You may ignore the screw below the tripod mount hole.
    • Remove the two 5.5 mm Phillips #00 screws on the side of the camera with the MIC jack.
    • Remove the two 7.0 mm Phillips #00 screws that are 1) above and 2) below the HDMI panel.
    • You may ignore the screw that goes through the leather material to the right of the HDMI panel.
    • There are two screws that hold the eye piece on to the main housing, just underneath. Remove these. Once these have been removed, gently pull and remove the eye piece and remove the now accessible top two screws.
  6. Panasonic Lumix DMC-FZ1000 Lens Replacement: stap 7, afbeelding 1 van 3 Panasonic Lumix DMC-FZ1000 Lens Replacement: stap 7, afbeelding 2 van 3 Panasonic Lumix DMC-FZ1000 Lens Replacement: stap 7, afbeelding 3 van 3
    • Do not yank off the back plate. If you do, you will tear the electronic ribbons attached to the inside of the camera and the back plate.
    • Gently lift up the back plate, being careful not to damage any ribbons.
    • Do not yank out the electronic ribbons attached to the motherboard and the back plate, or you may damage them. To properly detach these ZIF connector ribbons, see this technique on disconnecting ZIF connectors.
    • Pull to disconnect from the motherboard the two ZIF connector ribbons attached to the back plate.
    • Set aside the back plate.
  7. Panasonic Lumix DMC-FZ1000 Lens Replacement: stap 8, afbeelding 1 van 1
    • Do not yank out the electronic ribbons attached to the motherboard, or you may damage them. To properly detach these ZIF connector ribbons, see this technique on disconnecting ZIF connectors.
    • Pull to disconnect from the motherboard the seven ZIF connector ribbons.
  8. Panasonic Lumix DMC-FZ1000 Lens Replacement: stap 9, afbeelding 1 van 1
    • Remove the four 5.2 mm Phillips #00 screws at the corners of the motherboard.
  9. Panasonic Lumix DMC-FZ1000 Lens Replacement: stap 10, afbeelding 1 van 3 Panasonic Lumix DMC-FZ1000 Lens Replacement: stap 10, afbeelding 2 van 3 Panasonic Lumix DMC-FZ1000 Lens Replacement: stap 10, afbeelding 3 van 3
    • Firmly grasp the left side of the motherboard.
    • Pull out the motherboard.
    • If you find it difficult to remove the motherboard, pull it away from the HDMI panel while pulling it out.
  10. Panasonic Lumix DMC-FZ1000 Lens Replacement, Lens: stap 11, afbeelding 1 van 3 Panasonic Lumix DMC-FZ1000 Lens Replacement, Lens: stap 11, afbeelding 2 van 3 Panasonic Lumix DMC-FZ1000 Lens Replacement, Lens: stap 11, afbeelding 3 van 3
    • Remove the two 7.0 mm Phillips #00 screws on the underside of the viewfinder.
    • Pull out the viewfinder.
  11. Panasonic Lumix DMC-FZ1000 Lens Replacement: stap 12, afbeelding 1 van 1
    • Pull out the silver metal plate.
  12. Panasonic Lumix DMC-FZ1000 Lens Replacement: stap 13, afbeelding 1 van 3 Panasonic Lumix DMC-FZ1000 Lens Replacement: stap 13, afbeelding 2 van 3 Panasonic Lumix DMC-FZ1000 Lens Replacement: stap 13, afbeelding 3 van 3
    • Remove the four 9.0 mm Phillips #00 screws at the four corners of the lens.
    • Push up on the lens from the front/outside of the camera to remove it.
  13. Panasonic Lumix DMC-FZ1000 Lens Replacement: stap 14, afbeelding 1 van 2 Panasonic Lumix DMC-FZ1000 Lens Replacement: stap 14, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • In this step you will remove tape stuck to the top of several electronic ribbons. Be extremely careful when removing the tape, since the ribbons tear very easily.
    • Very carefully use tweezers to peel off the black tape between the lens and the metal cylinder.
    • Very carefully use tweezers to peel off the black tape on the right side of the lens.
  14. Panasonic Lumix DMC-FZ1000 Lens Replacement: stap 15, afbeelding 1 van 3 Panasonic Lumix DMC-FZ1000 Lens Replacement: stap 15, afbeelding 2 van 3 Panasonic Lumix DMC-FZ1000 Lens Replacement: stap 15, afbeelding 3 van 3
    • In this step you will tug on thin electronic ribbons with tweezers. Be extremely careful when pulling the ribbons, since they tear very easily. To properly detach these ZIF connector ribbons, see this technique on disconnecting ZIF connectors.
    • Using tweezers, very carefully pull to disconnect the ZIF connector ribbon between the lens and the metal cylinder.
    • Using tweezers, very carefully pull to disconnect the ZIF connector ribbon on the side of the lens.
  15. Panasonic Lumix DMC-FZ1000 Lens Replacement: stap 16, afbeelding 1 van 2 Panasonic Lumix DMC-FZ1000 Lens Replacement: stap 16, afbeelding 2 van 2
    • In this step you will unhook an electronic ribbon. Be careful when moving the ribbon, since it tears easily.
    • Use tweezers to unhook from its three pegs the electronic ribbon between the lens and the metal cylinder.
  16. Panasonic Lumix DMC-FZ1000 Lens Replacement: stap 17, afbeelding 1 van 1
    • Remove the two 5.0 mm Phillips #00 screws near the lens on top of the aperture motor.
  17. Panasonic Lumix DMC-FZ1000 Lens Replacement: stap 18, afbeelding 1 van 3 Panasonic Lumix DMC-FZ1000 Lens Replacement: stap 18, afbeelding 2 van 3 Panasonic Lumix DMC-FZ1000 Lens Replacement: stap 18, afbeelding 3 van 3
    • In this step you will move an electronic ribbon. Be careful when working with any piece of the ribbon, since it tears easily.
    • Carefully unhook the aperture motor from its two pegs and slowly move it towards the opposite side of the lens.
    • You may need to remove the Phillips screw that holds a trapezoid-shaped piece of the electronic ribbon.
    • While holding on to the aperture motor, very carefully use tweezers to unclip the electronic ribbon on the side of the lens.
  18. Panasonic Lumix DMC-FZ1000 Lens Replacement: stap 19, afbeelding 1 van 1
    • Set aside the aperture motor.
  19. Panasonic Lumix DMC-FZ1000 Lens Replacement: stap 20, afbeelding 1 van 2 Panasonic Lumix DMC-FZ1000 Lens Replacement: stap 20, afbeelding 2 van 2
    • Keep the front of the lens face down. There are springs between the sensor and the lens which may fall out.
    • Remove the three 4.0 mm Torx T5 screws attaching the sensor to the lens.
    • Pull out the sensor.
    • Pull out the three springs on top of the lens.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Robseth Taas
1.781 Reputatie
5 handleidingen geschreven
Cal Poly, Team 70-5, Forte Winter 2016 Lid van Cal Poly, Team 70-5, Forte Winter 2016
CPSU-FORTE-W16S70G5
4 Leden
15 handleidingen geschreven
2 opmerkingen
Where do I get a Lense Unit ? I need exactly that…for the FZ 1000
Mike Scholz - Antwoord
Hallo eine kurze Frage Bild /Schritt 15 ist um den Motor des Objektivantriebes ein Flachkabel unterbrochen. Muss das so oder ist es defekt? Es ist bei meiner Kamera genauso unterbrochen
STEVE GUTT - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 32
Afgelopen 30 dagen: 178
Altijd: 8,506
