Ga door naar hoofdinhoud
Panasonic Lumix DMC-FX9 Selector Buttons Replacement
Wat je nodig hebt
  1. Panasonic Lumix DMC-FX9 Selector Buttons Replacement, Selector Buttons: stap 1, afbeelding 1 van 1
    • Make sure the power is off by switching the power switch to the left.
  2. Panasonic Lumix DMC-FX9 Selector Buttons Replacement: stap 2, afbeelding 1 van 2 Panasonic Lumix DMC-FX9 Selector Buttons Replacement: stap 2, afbeelding 2 van 2
    • Use a Phillips #00 screwdriver to remove the screws on the left side of the camera.
  3. Panasonic Lumix DMC-FX9 Selector Buttons Replacement: stap 3, afbeelding 1 van 1
    • Remove the screws on the right side of the camera by using the Philips #00 screwdriver.
  4. Panasonic Lumix DMC-FX9 Selector Buttons Replacement: stap 4, afbeelding 1 van 2 Panasonic Lumix DMC-FX9 Selector Buttons Replacement: stap 4, afbeelding 2 van 2
    • Remove the screws on the bottom side of the camera using the Philips #00 Screwdriver.
    • Separate the covers by gently applying force upwards, carefully placing the opening tool between the two covers.
  5. Panasonic Lumix DMC-FX9 Selector Buttons Replacement: stap 5, afbeelding 1 van 2 Panasonic Lumix DMC-FX9 Selector Buttons Replacement: stap 5, afbeelding 2 van 2
    • Lift the ZIF tabs up with the opening tool and carefully remove the digitizer ribbon cables.
    • Remove the LCD Screen from the glass frame carefully with the opening tool.
  6. Panasonic Lumix DMC-FX9 Selector Buttons Replacement: stap 6, afbeelding 1 van 2 Panasonic Lumix DMC-FX9 Selector Buttons Replacement: stap 6, afbeelding 2 van 2
    • Push on the back panel buttons on the front side to remove the buttons.
    • Be cautious of the adhesive holding the button panels to the cover. Apply extra force if necessary.
Conclusie
Kriselle Tubongbanua
133 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 6
Altijd: 292
