Ga door naar hoofdinhoud
Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement
Wat je nodig hebt
  1. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement, Loose Digitizer Cable: stap 1, afbeelding 1 van 1
    • Power off your device by locating the on/off switch on top of camera.
  2. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: stap 2, afbeelding 1 van 3 Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: stap 2, afbeelding 2 van 3 Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: stap 2, afbeelding 3 van 3
    • Remove the screw located on the right side of the camera.
    • Remove the screw located on the bottom right of the camera, and remove the cover from the camera.
  3. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: stap 3, afbeelding 1 van 1
    • Remove the screw located on the base of the camera.
  4. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: stap 4, afbeelding 1 van 1
    • Pry the top part of the camera slowly. Be careful not to tear the digitilizer cable.
  5. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: stap 5, afbeelding 1 van 2 Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: stap 5, afbeelding 2 van 2
    • Open the bigger clamp using a spudger or other tools. Repeat for the smaller clamp.
  6. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: stap 6, afbeelding 1 van 2 Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: stap 6, afbeelding 2 van 2
    • Carefully take the thin ribbon and insert cable end into the latch. Do this for both sides.
  7. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: stap 7, afbeelding 1 van 3 Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: stap 7, afbeelding 2 van 3 Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: stap 7, afbeelding 3 van 3
    • Once the ribbon is placed into the latch, carefully close the clamps by lowering the clamp into a down position. Repeat this step for both sides.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 16
Altijd: 315
