Ga door naar hoofdinhoud
Panasonic Lumix DMC-FX07 Top Cover Replacement
Wat je nodig hebt
  1. Panasonic Lumix DMC-FX07 Top Cover Replacement, Battery: stap 1, afbeelding 1 van 1
    • Move the switch on the battery door to the Open position.
    • The door will automatically swing open after you let it go.
  2. Panasonic Lumix DMC-FX07 Top Cover Replacement: stap 2, afbeelding 1 van 2 Panasonic Lumix DMC-FX07 Top Cover Replacement: stap 2, afbeelding 2 van 2
    • Push the small gray tab on the top right corner to the left. The battery will pop out slightly.
    • Keep your finger clear of the battery when it pops out.
  3. Panasonic Lumix DMC-FX07 Top Cover Replacement, Memory Card: stap 3, afbeelding 1 van 1
    • Push the memory card in and let go.
    • The memory card will pop out slightly.
    • Pull out the memory card.
  4. Panasonic Lumix DMC-FX07 Top Cover Replacement, Back Cover: stap 4, afbeelding 1 van 2 Panasonic Lumix DMC-FX07 Top Cover Replacement, Back Cover: stap 4, afbeelding 2 van 2
    • Unscrew the small screws on the sides of the camera.
    • The screws on the left side(#00P, 4.7mm) are longer than the screw on the right side(#00P, 3.3mm).
  5. Panasonic Lumix DMC-FX07 Top Cover Replacement: stap 5, afbeelding 1 van 2 Panasonic Lumix DMC-FX07 Top Cover Replacement: stap 5, afbeelding 2 van 2
    • Unscrew the three small screws on the bottom(#00P, 3.3mm).
    • The bottom will fall off.
  6. Panasonic Lumix DMC-FX07 Top Cover Replacement: stap 6, afbeelding 1 van 3 Panasonic Lumix DMC-FX07 Top Cover Replacement: stap 6, afbeelding 2 van 3 Panasonic Lumix DMC-FX07 Top Cover Replacement: stap 6, afbeelding 3 van 3
    • Lift up the bottom back cover by prying the bottom edge with the spudger.
    • Gently lift up the back cover with your hand from the bottom to the top.
  7. Panasonic Lumix DMC-FX07 Top Cover Replacement: stap 7, afbeelding 1 van 3 Panasonic Lumix DMC-FX07 Top Cover Replacement: stap 7, afbeelding 2 van 3 Panasonic Lumix DMC-FX07 Top Cover Replacement: stap 7, afbeelding 3 van 3
    • Lift the tabs on the ZIF connectors.
    • The ribbon cables should easily come out of the ZIF connectors.
  8. Panasonic Lumix DMC-FX07 Top Cover Replacement, Top Cover: stap 8, afbeelding 1 van 2 Panasonic Lumix DMC-FX07 Top Cover Replacement, Top Cover: stap 8, afbeelding 2 van 2
    • Using the spudger, pry off the top cover by gliding the spudger along the entire edge between the top cover and the front cover.
    • Be careful not to damage the cylindrical capacitor on the circuit board under the top cover.
Conclusie
Karissa
50 Reputatie
8 handleidingen geschreven
Cal Poly, Team 6-23, Amido Spring 2012 Lid van Cal Poly, Team 6-23, Amido Spring 2012
CPSU-AMIDO-S12S6G23
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 15
Altijd: 776
