Ga door naar hoofdinhoud
Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement
Wat je nodig hebt
  1. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement, Battery: stap 1, afbeelding 1 van 1
    • Locate the memory card and battery card latch on the bottom of the camera.
    • Slide the latch to the open position.
  2. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: stap 2, afbeelding 1 van 1
    • Open the battery latch, and slide the battery release lever to the right.
  3. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: stap 3, afbeelding 1 van 1
    • Remove the battery from the camera.
  4. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement, Rear Casing: stap 4, afbeelding 1 van 1
    • Remove the three 4.6 mm screws on the bottom of the camera using a Phillips #00 screwdriver.
  5. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: stap 5, afbeelding 1 van 1
    • Remove the single 3.2 mm screw on the left side of the camera using a Phillips #00 screwdriver.
  6. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: stap 6, afbeelding 1 van 2 Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: stap 6, afbeelding 2 van 2
    • Remove the left side casing.
  7. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: stap 7, afbeelding 1 van 1
    • Remove the two 3.2 mm screws on the right side of the camera using a Phillips #00 screwdriver.
  8. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: stap 8, afbeelding 1 van 1
    • Remove the bottom right panel.
  9. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: stap 9, afbeelding 1 van 2 Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: stap 9, afbeelding 2 van 2
    • Gently remove the back casing.
    • Start at the bottom and carefully pry towards the top to get this piece free.
  10. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement, LCD Screen: stap 10, afbeelding 1 van 1
    • Gently lift up the LCD screen.
    • Using a plastic prying tool, flip up the latch that holds the thin ribbon in place.
    • It should fall out on its own or with a gentle tug.
  11. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: stap 11, afbeelding 1 van 1
    • Gently tug the thicker ribbon to remove it from its housing.
  12. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement, On/ Off Button and Settings Button: stap 12, afbeelding 1 van 2 Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement, On/ Off Button and Settings Button: stap 12, afbeelding 2 van 2
    • Carefully remove the upper assembly, which houses the buttons and the flash battery.
  13. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: stap 13, afbeelding 1 van 1
    • Remove the two 3mm screws.
  14. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: stap 14, afbeelding 1 van 2 Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: stap 14, afbeelding 2 van 2
    • Pry bars back gently as shown.
    • Fingers can be used but tool is shown for clarity.
  15. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: stap 15, afbeelding 1 van 2 Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: stap 15, afbeelding 2 van 2
    • After, releasing all the components, gently remove the flash assembly from the casing.
  16. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: stap 16, afbeelding 1 van 1
    • Remove the 1.2 mm screw from the settings wheel.
  17. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: stap 17, afbeelding 1 van 1
    • Replace buttons.
    • Replace the "On/ Off" button with the prongs facing away from the flash.
Conclusie
Andrew
396 Reputatie
4 handleidingen geschreven
Cal Poly, Team 9-22, Regan Fall 2010 Lid van Cal Poly, Team 9-22, Regan Fall 2010
CPSU-REGAN-F10S9G22
4 Leden
8 handleidingen geschreven
Één opmerking
Olá ! Sugiro ter cuidado com a carga do capacitor do flash, melhor descarrega-lo com auxílio de uma lâmpada ou resistor
para evitar um choque elétrico.
Ricardo Britto - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 6
Altijd: 5,085
