Wat je nodig hebt
Locate the memory card and battery card latch on the bottom of the camera.
Slide the latch to the open position.
Remove the three 4.6 mm screws on the bottom of the camera using a Phillips #00 screwdriver.
Gently lift up the LCD screen.
Using a plastic prying tool, flip up the latch that holds the thin ribbon in place.
It should fall out on its own or with a gentle tug.
Carefully remove the upper assembly, which houses the buttons and the flash battery.
Één opmerking
Olá ! Sugiro ter cuidado com a carga do capacitor do flash, melhor descarrega-lo com auxílio de uma lâmpada ou resistor
para evitar um choque elétrico.
