Ga door naar hoofdinhoud
Panasonic Lumix DMC-FX01 Lens Assembly Replacement
Wat je nodig hebt
  1. Panasonic Lumix DMC-FX01 Lens Assembly Replacement, Battery: stap 1, afbeelding 1 van 1
    • Locate the memory card and battery card latch on the bottom of the camera.
    • Slide the latch to the open position.
  2. Panasonic Lumix DMC-FX01 Lens Assembly Replacement: stap 2, afbeelding 1 van 1
    • Open the battery latch, and slide the battery release lever to the right.
  3. Panasonic Lumix DMC-FX01 Lens Assembly Replacement: stap 3, afbeelding 1 van 1
    • Remove the battery from the camera.
  4. Panasonic Lumix DMC-FX01 Lens Assembly Replacement, Rear Casing: stap 4, afbeelding 1 van 1
    • Remove the three 4.6 mm screws on the bottom of the camera using a Phillips #00 screwdriver.
  5. Panasonic Lumix DMC-FX01 Lens Assembly Replacement: stap 5, afbeelding 1 van 1
    • Remove the single 3.2 mm screw on the left side of the camera using a Phillips #00 screwdriver.
  6. Panasonic Lumix DMC-FX01 Lens Assembly Replacement: stap 6, afbeelding 1 van 2 Panasonic Lumix DMC-FX01 Lens Assembly Replacement: stap 6, afbeelding 2 van 2
    • Remove the left side casing.
  7. Panasonic Lumix DMC-FX01 Lens Assembly Replacement: stap 7, afbeelding 1 van 1
    • Remove the two 3.2 mm screws on the right side of the camera using a Phillips #00 screwdriver.
  8. Panasonic Lumix DMC-FX01 Lens Assembly Replacement: stap 8, afbeelding 1 van 1
    • Remove the bottom right panel.
  9. Panasonic Lumix DMC-FX01 Lens Assembly Replacement: stap 9, afbeelding 1 van 2 Panasonic Lumix DMC-FX01 Lens Assembly Replacement: stap 9, afbeelding 2 van 2
    • Gently remove the back casing.
    • Start at the bottom and carefully pry towards the top to get this piece free.
  10. Panasonic Lumix DMC-FX01 Lens Assembly Replacement, LCD Screen: stap 10, afbeelding 1 van 1
    • Gently lift up the LCD screen.
    • Using a plastic prying tool, flip up the latch that holds the thin ribbon in place.
    • It should fall out on its own or with a gentle tug.
  11. Panasonic Lumix DMC-FX01 Lens Assembly Replacement: stap 11, afbeelding 1 van 1
    • Gently tug the thicker ribbon to remove it from its housing.
  12. Panasonic Lumix DMC-FX01 Lens Assembly Replacement, Front Casing: stap 12, afbeelding 1 van 2 Panasonic Lumix DMC-FX01 Lens Assembly Replacement, Front Casing: stap 12, afbeelding 2 van 2
    • Remove the two black 5.4 mm screws that hold in the front faceplate using a Phillips #00 screwdriver.
    • There may be a third screw the the right of the lens assembly.
  13. Panasonic Lumix DMC-FX01 Lens Assembly Replacement: stap 13, afbeelding 1 van 3 Panasonic Lumix DMC-FX01 Lens Assembly Replacement: stap 13, afbeelding 2 van 3 Panasonic Lumix DMC-FX01 Lens Assembly Replacement: stap 13, afbeelding 3 van 3
    • Carefully remove the upper assembly, which houses the buttons and the flash battery.
  14. Panasonic Lumix DMC-FX01 Lens Assembly Replacement: stap 14, afbeelding 1 van 1
    • Carefully remove the front casing after verifying that the thin plastic around the lens is not still attached.
  15. Panasonic Lumix DMC-FX01 Lens Assembly Replacement, Lens Assembly: stap 15, afbeelding 1 van 2 Panasonic Lumix DMC-FX01 Lens Assembly Replacement, Lens Assembly: stap 15, afbeelding 2 van 2
    • Remove the three black 5mm screws attached to the lens frame.
  16. Panasonic Lumix DMC-FX01 Lens Assembly Replacement: stap 16, afbeelding 1 van 1
    • Remove the lens frame.
  17. Panasonic Lumix DMC-FX01 Lens Assembly Replacement: stap 17, afbeelding 1 van 1
    • Lift out the circuit board as shown.
  18. Panasonic Lumix DMC-FX01 Lens Assembly Replacement: stap 18, afbeelding 1 van 2 Panasonic Lumix DMC-FX01 Lens Assembly Replacement: stap 18, afbeelding 2 van 2
    • Lift the two black latches that hold the connector ribbons in place.
    • Disconnect the two ribbons.
  19. Panasonic Lumix DMC-FX01 Lens Assembly Replacement: stap 19, afbeelding 1 van 1
    • Remove the lens assembly as shown.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Steven
108 Reputatie
2 handleidingen geschreven
Cal Poly, Team 9-22, Regan Fall 2010 Lid van Cal Poly, Team 9-22, Regan Fall 2010
CPSU-REGAN-F10S9G22
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 16
Altijd: 9,599
