Inleiding
This guide shows how to remove the LCD screen from the circuit board and replace it.
Wat je nodig hebt
Locate the memory card and battery card latch on the bottom of the camera.
Slide the latch to the open position.
Remove the three 4.6 mm screws on the bottom of the camera using a Phillips #00 screwdriver.
Gently lift up the LCD screen.
Using a plastic prying tool, flip up the latch that holds the thin ribbon in place.
It should fall out on its own or with a gentle tug.
3 andere personen hebben deze handleiding voltooid.
