Ga door naar hoofdinhoud
Panasonic Lumix DMC-FX01 Flash Top Assembly Replacement
Wat je nodig hebt
  1. Panasonic Lumix DMC-FX01 Flash Top Assembly Replacement, Battery: stap 1, afbeelding 1 van 1
    • Locate the memory card and battery card latch on the bottom of the camera.
    • Slide the latch to the open position.
  2. Panasonic Lumix DMC-FX01 Flash Top Assembly Replacement: stap 2, afbeelding 1 van 1
    • Open the battery latch, and slide the battery release lever to the right.
  3. Panasonic Lumix DMC-FX01 Flash Top Assembly Replacement: stap 3, afbeelding 1 van 1
    • Remove the battery from the camera.
  4. Panasonic Lumix DMC-FX01 Flash Top Assembly Replacement, Rear Casing: stap 4, afbeelding 1 van 1
    • Remove the three 4.6 mm screws on the bottom of the camera using a Phillips #00 screwdriver.
  5. Panasonic Lumix DMC-FX01 Flash Top Assembly Replacement: stap 5, afbeelding 1 van 1
    • Remove the single 3.2 mm screw on the left side of the camera using a Phillips #00 screwdriver.
  6. Panasonic Lumix DMC-FX01 Flash Top Assembly Replacement: stap 6, afbeelding 1 van 2 Panasonic Lumix DMC-FX01 Flash Top Assembly Replacement: stap 6, afbeelding 2 van 2
    • Remove the left side casing.
  7. Panasonic Lumix DMC-FX01 Flash Top Assembly Replacement: stap 7, afbeelding 1 van 1
    • Remove the two 3.2 mm screws on the right side of the camera using a Phillips #00 screwdriver.
  8. Panasonic Lumix DMC-FX01 Flash Top Assembly Replacement: stap 8, afbeelding 1 van 1
    • Remove the bottom right panel.
  9. Panasonic Lumix DMC-FX01 Flash Top Assembly Replacement: stap 9, afbeelding 1 van 2 Panasonic Lumix DMC-FX01 Flash Top Assembly Replacement: stap 9, afbeelding 2 van 2
    • Gently remove the back casing.
    • Start at the bottom and carefully pry towards the top to get this piece free.
  10. Panasonic Lumix DMC-FX01 Flash Top Assembly Replacement, Flash Top Assembly: stap 10, afbeelding 1 van 2 Panasonic Lumix DMC-FX01 Flash Top Assembly Replacement, Flash Top Assembly: stap 10, afbeelding 2 van 2
    • Carefully pry the Flash Top Assembly away from the top.
  11. Panasonic Lumix DMC-FX01 Flash Top Assembly Replacement: stap 11, afbeelding 1 van 2 Panasonic Lumix DMC-FX01 Flash Top Assembly Replacement: stap 11, afbeelding 2 van 2
    • Replace the Flash Top Assembly with a new one.
Conclusie
Caleb Fink
191 Reputatie
2 handleidingen geschreven
Cal Poly, Team 9-22, Regan Fall 2010 Lid van Cal Poly, Team 9-22, Regan Fall 2010
CPSU-REGAN-F10S9G22
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 17
Altijd: 3,863
