Ga door naar hoofdinhoud
Panasonic Lumix DMC-FH25 LCD Screen Replacement
Wat je nodig hebt
  1. Panasonic Lumix DMC-FH25 LCD Screen Replacement, Back Case: stap 1, afbeelding 1 van 3 Panasonic Lumix DMC-FH25 LCD Screen Replacement, Back Case: stap 1, afbeelding 2 van 3 Panasonic Lumix DMC-FH25 LCD Screen Replacement, Back Case: stap 1, afbeelding 3 van 3
    • Remove 5 screws attached to the back case using a 00 Phillips head screwdriver.
  2. Panasonic Lumix DMC-FH25 LCD Screen Replacement: stap 2, afbeelding 1 van 1
    • Using your hands and a pry tool, lever the back case off.
  3. Panasonic Lumix DMC-FH25 LCD Screen Replacement: stap 3, afbeelding 1 van 2 Panasonic Lumix DMC-FH25 LCD Screen Replacement: stap 3, afbeelding 2 van 2
    • Remove the back case.
  4. Panasonic Lumix DMC-FH25 LCD Screen Replacement, LCD Screen: stap 4, afbeelding 1 van 3 Panasonic Lumix DMC-FH25 LCD Screen Replacement, LCD Screen: stap 4, afbeelding 2 van 3 Panasonic Lumix DMC-FH25 LCD Screen Replacement, LCD Screen: stap 4, afbeelding 3 van 3
    • Using a 00 Phillips head screwdriver, remove a screw from the top right corner of the screen.
    • Lift the screen, being careful not to tear the ribbon cables on the right side.
  5. Panasonic Lumix DMC-FH25 LCD Screen Replacement: stap 5, afbeelding 1 van 2 Panasonic Lumix DMC-FH25 LCD Screen Replacement: stap 5, afbeelding 2 van 2
    • Access the ribbon cables by removing the green button receiver panel using a plastic opening tool. There is a white panel beneath. Carefully remove this using a plastic opening tool. The white panel may require some elbow grease to get it off, and the panel may make a snapping sound as it comes off.
  6. Panasonic Lumix DMC-FH25 LCD Screen Replacement: stap 6, afbeelding 1 van 2 Panasonic Lumix DMC-FH25 LCD Screen Replacement: stap 6, afbeelding 2 van 2
    • One of the ribbon cables will be housed behind the screen and the other will be under the panels. Gently pull each free from the housing and remove the screen.
Conclusie
Janice Weldon
612 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team S6-G6, Isaacson Spring 2017 Lid van UMass Dartmouth, Team S6-G6, Isaacson Spring 2017
UMASSD-ISAACSON-S17S6G6
3 Leden
10 handleidingen geschreven
Één opmerking
it has been quite easy tank you for sharing your help serge jobin
Serge Jobin - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 15
Altijd: 452
