Ga door naar hoofdinhoud
Panasonic Lumix DMC-FH20 LCD Screen Replacement
Wat je nodig hebt
  1. Panasonic Lumix DMC-FH20 LCD Screen Replacement, LCD Screen: stap 1, afbeelding 1 van 3 Panasonic Lumix DMC-FH20 LCD Screen Replacement, LCD Screen: stap 1, afbeelding 2 van 3 Panasonic Lumix DMC-FH20 LCD Screen Replacement, LCD Screen: stap 1, afbeelding 3 van 3
    • Remove all screws (Phillips #000 head) from the sides and bottom of the camera.
  2. Panasonic Lumix DMC-FH20 LCD Screen Replacement: stap 2, afbeelding 1 van 1
    • Remove the back panel. This might require some extra force. If you still can't get the panel off, try to use a plastic opening tool.
  3. Panasonic Lumix DMC-FH20 LCD Screen Replacement: stap 3, afbeelding 1 van 2 Panasonic Lumix DMC-FH20 LCD Screen Replacement: stap 3, afbeelding 2 van 2
    • Remove the circuit board. You should be able to do this with your fingers. Just grab it and pull upwards. If it does not come, use a plastic opening tool to help.
  4. Panasonic Lumix DMC-FH20 LCD Screen Replacement: stap 4, afbeelding 1 van 2 Panasonic Lumix DMC-FH20 LCD Screen Replacement: stap 4, afbeelding 2 van 2
    • Remove the white plastic cover. This may take some extra force. You will want to try to remove from the bottom side first and peel up.
    • Then, where the silver switch is located, it will slide directly out at the top.
  5. Panasonic Lumix DMC-FH20 LCD Screen Replacement: stap 5, afbeelding 1 van 1
    • Unscrew one screw (Phillips #000 head).
  6. Panasonic Lumix DMC-FH20 LCD Screen Replacement: stap 6, afbeelding 1 van 3 Panasonic Lumix DMC-FH20 LCD Screen Replacement: stap 6, afbeelding 2 van 3 Panasonic Lumix DMC-FH20 LCD Screen Replacement: stap 6, afbeelding 3 van 3
    • You will want to use a plastic opening tool to complete this step. Pop the thin black piece of plastic upwards with the opening tool to unlock the plastic film ribbon.
    • Once unlocked, you will be able to pull the ribbon out and remove the screen completely.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Arianna Boushell
626 Reputatie
5 handleidingen geschreven
Cal Poly, Team 10-7, Banghart Winter 2017 Lid van Cal Poly, Team 10-7, Banghart Winter 2017
CPSU-BANGHART-W17S10G7
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 16
Altijd: 554
