Inleiding
Fixing the lens apparatus on your camera.
Gereedschap
Onderdelen
Geen onderdelen nodig.
Lay the camera on its front side./combine this sentence to the step below.
Use Spudger tool to open the film strip locking mechanism and remove strip./No edits necessary.
Hold down on the camera's metal casing with one hand. Using your other hand, completely lift the back case off the rest of the camera, making sure the film strip separates./Make a picture for this step.
Remove the two remaining 2.8 mm Phillips screws on the bottom of the camera.
Using Spudger tool, pry the front case from the camera's components.
Use your fingers to carefully pull the back case from the front case.
Cut the black and red wires connecting front case to the body of the camera.
Be careful nothing gets caught, and separate the front case from the camera.
Één andere persoon heeft deze handleiding voltooid.
