Ga door naar hoofdinhoud
Panasonic Lumix DMC-F7 Battery Replacement
  1. Panasonic Lumix DMC-F7 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Slide the lock switch to the right so that it is in the unlocked position.
    • Use your finger to slide the battery hatch in the direction of the downward arrow so that the hatch is open.
    • Both battery and memory card should now be visible.
  2. Panasonic Lumix DMC-F7 Battery Replacement: stap 2, afbeelding 1 van 1
    • Open the battery hatch and then the black cover to expose the battery compartment.
    • The camera used to create these repair guides did not have a battery and memory card.
    • Remove the battery.
    • When installing the new battery, ensure it is in the same orientation as before.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Hormoz Tarevern
170 Reputatie
1 Handleiding geschreven
Cal Poly, Team 7-35, Regan Winter 2011 Lid van Cal Poly, Team 7-35, Regan Winter 2011
CPSU-REGAN-W11S7G35
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 2,301
