Ga door naar hoofdinhoud
Panasonic KX-TGE233 TEL Port Replacement
Wat je nodig hebt
  1. Panasonic KX-TGE233 TEL Port Replacement, Base Front Panel Assembly: stap 1, afbeelding 1 van 1
    • To fix this component, we'll need to work with the main docking station. This is the one with the answering machine and the TEL line.
  2. Panasonic KX-TGE233 TEL Port Replacement: stap 2, afbeelding 1 van 1
    • To start, we'll need to work with objects on the bottom of the device, so begin by flipping the device over.
  3. Panasonic KX-TGE233 TEL Port Replacement: stap 3, afbeelding 1 van 1
    • To open the main docking station, you'll need to remove four 11 mm Philips #0 screws.
  4. Panasonic KX-TGE233 TEL Port Replacement: stap 4, afbeelding 1 van 1
    • With the screws removed, you can use a spudger to aid in removing the back from the device.
    • Levering the back by the spudger may break the tool!
  5. Panasonic KX-TGE233 TEL Port Replacement: stap 5, afbeelding 1 van 1
    • With the back removed, we now have direct access to all other components in the main docking station.
  6. Panasonic KX-TGE233 TEL Port Replacement, TEL Port: stap 6, afbeelding 1 van 1
    • For easier access to its wires, you can easily remove the TEL port from its resting point in the device.
  7. Panasonic KX-TGE233 TEL Port Replacement: stap 7, afbeelding 1 van 1
  8. Panasonic KX-TGE233 TEL Port Replacement: stap 8, afbeelding 1 van 1
    • From here, you can remove the faulty port from the device. If the soldering step has been completed successfully, this should require minimal effort.
Conclusie
Jesse Satterwhite
682 Reputatie
5 handleidingen geschreven
IUPUI, Team 2-2, Baechle Spring 2016 Lid van IUPUI, Team 2-2, Baechle Spring 2016
IUPUI-BAECHLE-S16S2G2
5 Leden
15 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 54
Altijd: 765
