Ga door naar hoofdinhoud
Panasonic KX-TGE233 Base Front Panel Assembly Replacement
Wat je nodig hebt
  1. Panasonic KX-TGE233 Base Front Panel Assembly Replacement, Base Front Panel Assembly: stap 1, afbeelding 1 van 1
    • To fix this component, we'll need to work with the main docking station. This is the one with the answering machine and the TEL line.
  2. Panasonic KX-TGE233 Base Front Panel Assembly Replacement: stap 2, afbeelding 1 van 1
    • To start, we'll need to work with objects on the bottom of the device, so begin by flipping the device over.
  3. Panasonic KX-TGE233 Base Front Panel Assembly Replacement: stap 3, afbeelding 1 van 1
    • To open the main docking station, you'll need to remove four 11 mm Philips #0 screws.
  4. Panasonic KX-TGE233 Base Front Panel Assembly Replacement: stap 4, afbeelding 1 van 1
    • With the screws removed, you can use a spudger to aid in removing the back from the device.
    • Levering the back by the spudger may break the tool!
  5. Panasonic KX-TGE233 Base Front Panel Assembly Replacement: stap 5, afbeelding 1 van 1
    • With the back removed, we now have direct access to all other components in the main docking station.
Conclusie
Jesse Satterwhite
682 Reputatie
5 handleidingen geschreven
IUPUI, Team 2-2, Baechle Spring 2016 Lid van IUPUI, Team 2-2, Baechle Spring 2016
IUPUI-BAECHLE-S16S2G2
5 Leden
15 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 9
Altijd: 483
