Ga door naar hoofdinhoud
Panasonic KX-TG6021M Front Speaker Replacement
Wat je nodig hebt
  1. Panasonic KX-TG6021M Front Speaker Replacement, Battery: stap 1, afbeelding 1 van 2 Panasonic KX-TG6021M Front Speaker Replacement, Battery: stap 1, afbeelding 2 van 2
    • Slide the back cover down towards the bottom of the phone to remove.
  2. Panasonic KX-TG6021M Front Speaker Replacement: stap 2, afbeelding 1 van 3 Panasonic KX-TG6021M Front Speaker Replacement: stap 2, afbeelding 2 van 3 Panasonic KX-TG6021M Front Speaker Replacement: stap 2, afbeelding 3 van 3
    • Pull the top of the battery towards you to remove it from the phone.
  3. Panasonic KX-TG6021M Front Speaker Replacement, Front Panel: stap 3, afbeelding 1 van 2 Panasonic KX-TG6021M Front Speaker Replacement, Front Panel: stap 3, afbeelding 2 van 2
    • Unscrew the two screws located at the bottom of the phone.
    • Use a PH00 Phillips head to remove the 9 mm screws.
  4. Panasonic KX-TG6021M Front Speaker Replacement: stap 4, afbeelding 1 van 3 Panasonic KX-TG6021M Front Speaker Replacement: stap 4, afbeelding 2 van 3 Panasonic KX-TG6021M Front Speaker Replacement: stap 4, afbeelding 3 van 3
    • Separate the back cover from the front cover by using a wedge.
    • Remove the back cover from the front cover by pulling them apart.
  5. Panasonic KX-TG6021M Front Speaker Replacement: stap 5, afbeelding 1 van 1
    • Remove three screws on the motherboard.
    • Pull the phone face off of the motherboard.
  6. Panasonic KX-TG6021M Front Speaker Replacement, Front Speaker: stap 6, afbeelding 1 van 1
    • Remove the front speaker housing by detaching it from the circuit board.
  7. Panasonic KX-TG6021M Front Speaker Replacement: stap 7, afbeelding 1 van 1
    • Pop out the front speaker from the housing.
  8. Panasonic KX-TG6021M Front Speaker Replacement: stap 8, afbeelding 1 van 1
    • Desolder the two connections and remove the wires from the circuit board.
Conclusie
paul scruggs
177 Reputatie
1 Handleiding geschreven
IUPUI, Team 3-1, Baechle Fall 2016 Lid van IUPUI, Team 3-1, Baechle Fall 2016
IUPUI-BAECHLE-F16S3G1
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 7
Altijd: 211
