Ga door naar hoofdinhoud
Panasonic HDC-TM15 Side Cover Replacement
Wat je nodig hebt
  1. Panasonic HDC-TM15 Side Cover Replacement, Side Cover: stap 1, afbeelding 1 van 1
    • Using the Phillips #00 Screwdriver, unscrew the five .5 mm Phillips #00 screws on the hand-strap side of the camcorder.
  2. Panasonic HDC-TM15 Side Cover Replacement: stap 2, afbeelding 1 van 1
    • Next, unscrew the six .5 mm Phillips #00 screws on the bottom of the camcorder.
  3. Panasonic HDC-TM15 Side Cover Replacement: stap 3, afbeelding 1 van 3 Panasonic HDC-TM15 Side Cover Replacement: stap 3, afbeelding 2 van 3 Panasonic HDC-TM15 Side Cover Replacement: stap 3, afbeelding 3 van 3
    • By putting your hand through the hand-strap, tug on the side cover until it comes off completely.
    • Once the old cover is completely detached, set it aside.
    • The inside of your camcorder should now be completely exposed, as seen in the photos.
  4. Panasonic HDC-TM15 Side Cover Replacement: stap 4, afbeelding 1 van 2 Panasonic HDC-TM15 Side Cover Replacement: stap 4, afbeelding 2 van 2
    • Line up the new side cover in the exact same place, ensuring that the screw holes match.
    • Re-screw the side cover into place.
  5. Panasonic HDC-TM15 Side Cover Replacement: stap 5, afbeelding 1 van 1
    • Gently tug on the hand-strap to ensure that the screws are tight and the side cover is secure.
    • When the side cover is securely fastened, you have completed the side cover replacement of your Panasonic HDC-TM15 camcorder.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Tricia Fallo
210 Reputatie
2 handleidingen geschreven
Marist, Team 1-4, Laflen Spring 2015 Lid van Marist, Team 1-4, Laflen Spring 2015
MARS-LAFLEN-S15S1G4
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 304
