Ga door naar hoofdinhoud
Panasonic HDC-TM15 Hand-Strap Replacement
Wat je nodig hebt
  1. Panasonic HDC-TM15 Hand-Strap Replacement, Hand-Strap: stap 1, afbeelding 1 van 1
    • Using the Phillips #00 Screwdriver, unscrew the five .5 mm Phillips #00 screws on the hand-strap side of the camcorder.
  2. Panasonic HDC-TM15 Hand-Strap Replacement: stap 2, afbeelding 1 van 1
    • Unscrew the six .5 mm Phillips #00 screws on the bottom of the camcorder.
  3. Panasonic HDC-TM15 Hand-Strap Replacement: stap 3, afbeelding 1 van 3 Panasonic HDC-TM15 Hand-Strap Replacement: stap 3, afbeelding 2 van 3 Panasonic HDC-TM15 Hand-Strap Replacement: stap 3, afbeelding 3 van 3
    • Once all eleven screws have been removed, put your hand through the hand-strap and tug on the side cover until it comes off completely.
    • The inside of your camcorder should now be completely exposed, as shown in the photos.
  4. Panasonic HDC-TM15 Hand-Strap Replacement: stap 4, afbeelding 1 van 3 Panasonic HDC-TM15 Hand-Strap Replacement: stap 4, afbeelding 2 van 3 Panasonic HDC-TM15 Hand-Strap Replacement: stap 4, afbeelding 3 van 3
    • For the remainder of the hand-strap replacement, you will only be working with the side cover of the camcorder.
    • Unscrew the two silver .5 mm Phillips #00 screws located in the bottom corners of the inside of the side cover. This will release the two silver plates that hold the hand-strap in place.
  5. Panasonic HDC-TM15 Hand-Strap Replacement: stap 5, afbeelding 1 van 2 Panasonic HDC-TM15 Hand-Strap Replacement: stap 5, afbeelding 2 van 2
    • Remove the two silver plates from the loops of the hand-strap.
  6. Panasonic HDC-TM15 Hand-Strap Replacement: stap 6, afbeelding 1 van 1
    • Pull the hand-strap through the holes of the side cover, until it is completely detached.
    • Set the old hand-strap aside.
  7. Panasonic HDC-TM15 Hand-Strap Replacement: stap 7, afbeelding 1 van 3 Panasonic HDC-TM15 Hand-Strap Replacement: stap 7, afbeelding 2 van 3 Panasonic HDC-TM15 Hand-Strap Replacement: stap 7, afbeelding 3 van 3
    • During these next replacement steps, the inside of the side cover should be facing you.
    • Taking your new hand-strap, first feed the smaller loop through the bottom right hole of the side cover.
  8. Panasonic HDC-TM15 Hand-Strap Replacement: stap 8, afbeelding 1 van 2 Panasonic HDC-TM15 Hand-Strap Replacement: stap 8, afbeelding 2 van 2
    • Feed the hooked end of the smaller silver plate through the first loop of the new hand-strap.
    • Slide the sliver plate into place, lining up the screw holes, and screw in tightly.
  9. Panasonic HDC-TM15 Hand-Strap Replacement: stap 9, afbeelding 1 van 2 Panasonic HDC-TM15 Hand-Strap Replacement: stap 9, afbeelding 2 van 2
    • Feed the larger loop through the hole in the opposite corner of the side cover.
  10. Panasonic HDC-TM15 Hand-Strap Replacement: stap 10, afbeelding 1 van 2 Panasonic HDC-TM15 Hand-Strap Replacement: stap 10, afbeelding 2 van 2
    • Feed the U-shaped silver plate through the second, larger loop of the new hand-strap in the opposite corner of the side cover.
    • Ensure the screw hole is lined up.
  11. Panasonic HDC-TM15 Hand-Strap Replacement: stap 11, afbeelding 1 van 1
    • Re-screw the two silver screws tightly back into the silver plates.
  12. Panasonic HDC-TM15 Hand-Strap Replacement: stap 12, afbeelding 1 van 1
    • Tug on the hand-strap to ensure it is securely in place.
    • If your new hand-strap feels secure, you can now re-attach the side cover to your camcorder.
  13. Panasonic HDC-TM15 Hand-Strap Replacement: stap 13, afbeelding 1 van 1
    • When the side cover is securely fastened, you have completed the hand-strap replacement of your Panasonic HDC-TM15 camcorder.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Tricia Fallo
210 Reputatie
2 handleidingen geschreven
Marist, Team 1-4, Laflen Spring 2015 Lid van Marist, Team 1-4, Laflen Spring 2015
MARS-LAFLEN-S15S1G4
3 Leden
6 handleidingen geschreven
Één opmerking
Any idea where the replacement strap can be purchased? Thank you
Suzi Finkenbine - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 870
