Ga door naar hoofdinhoud
Panasonic HC‑VX870 Hand Strap Replacement
Wat je nodig hebt
  1. Panasonic HC‑VX870 Hand Strap Replacement, Side Cover: stap 1, afbeelding 1 van 3 Panasonic HC‑VX870 Hand Strap Replacement, Side Cover: stap 1, afbeelding 2 van 3 Panasonic HC‑VX870 Hand Strap Replacement, Side Cover: stap 1, afbeelding 3 van 3
    • Unscrew the J1 screws on the left side of the camcorder.
    • Unscrew the marked screws on the bottom of the camcorder.
    • Unscrew the marked screws on the back of the camcorder.
  2. Panasonic HC‑VX870 Hand Strap Replacement: stap 2, afbeelding 1 van 2 Panasonic HC‑VX870 Hand Strap Replacement: stap 2, afbeelding 2 van 2
    • Pull off the left side of the camcorder. You may have to use a little force but don't worry about breaking anything in the camcorder.
  3. Panasonic HC‑VX870 Hand Strap Replacement, Record Button Mechanism: stap 3, afbeelding 1 van 1
    • Unscrew the indicated screw.
  4. Panasonic HC‑VX870 Hand Strap Replacement: stap 4, afbeelding 1 van 1
    • Lift up on the little tab indicated in the picture and push away from the camera in order to remove the record button.
  5. Panasonic HC‑VX870 Hand Strap Replacement: stap 5, afbeelding 1 van 3 Panasonic HC‑VX870 Hand Strap Replacement: stap 5, afbeelding 2 van 3 Panasonic HC‑VX870 Hand Strap Replacement: stap 5, afbeelding 3 van 3
    • Take out the piece that that was held in place by the screw and separate the smaller piece from the larger piece.
  6. Panasonic HC‑VX870 Hand Strap Replacement, Hand Strap: stap 6, afbeelding 1 van 1
    • Use the plastic opening tool to pry the little metal bar out of place in order to release one side of the hand strap.
  7. Panasonic HC‑VX870 Hand Strap Replacement: stap 7, afbeelding 1 van 1
    • Unscrew the indicated screws and remove the piece it was holding in place.
  8. Panasonic HC‑VX870 Hand Strap Replacement: stap 8, afbeelding 1 van 1
    • Repeat step 3 for this side of the strap.
  9. Panasonic HC‑VX870 Hand Strap Replacement: stap 9, afbeelding 1 van 1
    • Pull the handle straps out of their holes to remove the strap.
Conclusie
Rebecca Maloney
501 Reputatie
5 handleidingen geschreven
Cal Poly, Team 13-6, Banghart Winter 2017 Lid van Cal Poly, Team 13-6, Banghart Winter 2017
CPSU-BANGHART-W17S13G6
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 15
Altijd: 593
