Inleiding
Upon purchase of the trimmer, battery would not be included. Therefore this guide would be of help to replace the battery into the trimmer.
Wat je nodig hebt
Remove the battery cover by rotating it counter -clockwise and lifting it off.
Tilt the trimmer to the bottom, you will notice the battery housing.
2 opmerkingen
Battery + side goes in first (when battery is inserted correctly, the - side will be facing you).
i prided the negative tab on the cover up to make contact. the trimmer roared to life again!
