Ga door naar hoofdinhoud
Panasonic ER-GN30-K Motor Shaft Replacement
Wat je nodig hebt
  1. Panasonic ER-GN30-K Motor Shaft Replacement, Motor Shaft: stap 1, afbeelding 1 van 1
    • Remove the dark transparent cap by gently pulling on it.
  2. Panasonic ER-GN30-K Motor Shaft Replacement: stap 2, afbeelding 1 van 1
    • Remove the back battery cap from the device by twisting it to the unlock position and pulling.
  3. Panasonic ER-GN30-K Motor Shaft Replacement: stap 3, afbeelding 1 van 1
    • Remove the black trimmer cap from the top of the device by gently pulling it.
  4. Panasonic ER-GN30-K Motor Shaft Replacement: stap 4, afbeelding 1 van 1
    • The motor shaft should be sticking out from the top of the device.
    • Use the metal prying tool to pry apart the silver plastic case .
    • Pull each side of the plastic case off.
  5. Panasonic ER-GN30-K Motor Shaft Replacement: stap 5, afbeelding 1 van 1
    • Unscrew one 20mm Phillips #00 screw.
  6. Panasonic ER-GN30-K Motor Shaft Replacement: stap 6, afbeelding 1 van 1
    • Remove the rubber stopper from the top of the motor shaft by gently pulling it off.
  7. Panasonic ER-GN30-K Motor Shaft Replacement: stap 7, afbeelding 1 van 2 Panasonic ER-GN30-K Motor Shaft Replacement: stap 7, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Use a pair of tweezers to remove the plastic cover of the motor shaft by pulling it away from the motor.
Conclusie
Alejandro Garabatos
330 Reputatie
2 handleidingen geschreven
USF Tampa, Team 15-3, Blackwell Fall 2015 Lid van USF Tampa, Team 15-3, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G3
4 Leden
5 handleidingen geschreven
2 opmerkingen
Thank you, small parts where switch is could be shown as well. Would be very helpful.
Advise for putting things back together: remove plastic switch cover and put back only after full reassembly
Aurimas Miko - Antwoord
Dear Alejandro,
thank You for your instruction, my question is where this motor shaft part is available? I can’t find it anywhere on the net. Thanks if you can help. Bence Fazekas
fazebence - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 19
Altijd: 1,584
