Ga door naar hoofdinhoud
Panasonic ER-GN30-K Motor Replacement
Wat je nodig hebt
  1. Panasonic ER-GN30-K Motor Replacement, Motor: stap 1, afbeelding 1 van 1
    • Remove the dark transparent cap by gently pulling on it.
  2. Panasonic ER-GN30-K Motor Replacement: stap 2, afbeelding 1 van 1
    • Remove the back battery cap from the device by twisting it to the unlock position and pulling.
  3. Panasonic ER-GN30-K Motor Replacement: stap 3, afbeelding 1 van 1
    • Remove the black trimmer cap from the top of the device by gently pulling it.
  4. Panasonic ER-GN30-K Motor Replacement: stap 4, afbeelding 1 van 1
    • Use a metal spudger to pry apart the silver plastic case.
    • Pull each side of the plastic case off.
  5. Panasonic ER-GN30-K Motor Replacement: stap 5, afbeelding 1 van 1
    • Unscrew one 20mm Phillips #00 screw.
  6. Panasonic ER-GN30-K Motor Replacement: stap 6, afbeelding 1 van 1
    • Remove the rubber stopper from the top of the motor shaft by gently pulling it off.
  7. Panasonic ER-GN30-K Motor Replacement: stap 7, afbeelding 1 van 2 Panasonic ER-GN30-K Motor Replacement: stap 7, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Use a pair of tweezers to remove the plastic cover of the motor shaft by pulling it away from the motor.
  8. Panasonic ER-GN30-K Motor Replacement: stap 8, afbeelding 1 van 1
    • Remove the motor from the case by sliding the cover off of it.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Corey Tappan
209 Reputatie
1 Handleiding geschreven
USF Tampa, Team 15-3, Blackwell Fall 2015 Lid van USF Tampa, Team 15-3, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G3
4 Leden
5 handleidingen geschreven
Één opmerking
My motor working intermittently. Took apart per instruction (very detailed, thank you). Everything loos good on the internals. I think my problem is succumb build up on the negative spring where it makes contact on negative end of battery. I scrapped it a little with tip of knife, working some what better. Need to find small wire brush to get in there and give it a good cleaning. Thank you for your guide :)
Rocko the fixit cat - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 32
Altijd: 3,498
