Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Wat je nodig hebt
Eject the disk tray from the DVD player before removing power supply.
Remove the three screws running along the back edge of case cover.
Remove the two screws from each side of the case cover.
Lift up the 5 tabs securing the front panel to the chassis. There are 3 on the bottom, and 2 on the inside edges of the panel. Panel should then lift off the player.
