Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Eject the disk tray from the DVD player before removing power supply.
Remove 3 screws running along back edge of case cover.
Remove 2 screws from each side of case cover.
Lift up the 5 tabs securing the front panel to the chassis. There are 3 on the bottom, and 2 on the inside edges of the panel. Panel should then lift off the player.
Locate the 4 screws securing the disk drive assembly. There are two on each side.
Use a narrow screwdriver to remove all 4 screws.
Remove the blue ribbon wire from its connector. When doing this, be cautious to not damage the connector.
