Ga door naar hoofdinhoud
Panasonic DMC-FZ70 Back Frame Replacement
Wat je nodig hebt
  1. Panasonic DMC-FZ70 Back Frame Replacement, Back Panel: stap 1, afbeelding 1 van 2 Panasonic DMC-FZ70 Back Frame Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • All screws should be removed using a Phillips #0 screwdriver.
    • Using your screwdriver, unscrew the two 5.0 mm Philips screws to the right of the LCD screen.
  2. Panasonic DMC-FZ70 Back Frame Replacement: stap 2, afbeelding 1 van 2 Panasonic DMC-FZ70 Back Frame Replacement: stap 2, afbeelding 2 van 2
    • Flip the camera over to the left side of the screen and unscrew the 5mm Phillips screw found there.
  3. Panasonic DMC-FZ70 Back Frame Replacement: stap 3, afbeelding 1 van 2 Panasonic DMC-FZ70 Back Frame Replacement: stap 3, afbeelding 2 van 2
    • Turn the camera upside down and unscrew the three 5mm screws found on the bottom.
  4. Panasonic DMC-FZ70 Back Frame Replacement: stap 4, afbeelding 1 van 2 Panasonic DMC-FZ70 Back Frame Replacement: stap 4, afbeelding 2 van 2
    • On the top of the camera locate the two rails with a thin sheet of metal on the floor between them.
    • With a metal spudger, lift this sheet and push it out of the rail device to detach it from the camera.
  5. Panasonic DMC-FZ70 Back Frame Replacement: stap 5, afbeelding 1 van 1
    • Proceed to remove the four 5mm Phillips screws that you just uncovered.
  6. Panasonic DMC-FZ70 Back Frame Replacement: stap 6, afbeelding 1 van 1
    • Slowly pull on both side of the camera, until both halves begin to separate from each other.
    • Do not pull too hard, as both halves are held together with ZIF connector cables.
  7. Panasonic DMC-FZ70 Back Frame Replacement: stap 7, afbeelding 1 van 3 Panasonic DMC-FZ70 Back Frame Replacement: stap 7, afbeelding 2 van 3 Panasonic DMC-FZ70 Back Frame Replacement: stap 7, afbeelding 3 van 3
    • Using a plastic opening tool, carefully flip up the small black levers that attach the ribbon cables to the ZIF connectors on the motherboard.
    • Carefully pull the ribbon cables out of the slot once they have been released.
    • Only the two indicated connectors need to be removed to separate the two halves of the camera.
  8. Panasonic DMC-FZ70 Back Frame Replacement, LCD Screen: stap 8, afbeelding 1 van 2 Panasonic DMC-FZ70 Back Frame Replacement, LCD Screen: stap 8, afbeelding 2 van 2
    • Unscrew the five 5mm screws on the panel that you just removed.
  9. Panasonic DMC-FZ70 Back Frame Replacement: stap 9, afbeelding 1 van 2 Panasonic DMC-FZ70 Back Frame Replacement: stap 9, afbeelding 2 van 2
    • Remove the entire silver panel to reveal the back of the LCD screen
  10. Panasonic DMC-FZ70 Back Frame Replacement: stap 10, afbeelding 1 van 1
    • Remove the LCD screen.
  11. Panasonic DMC-FZ70 Back Frame Replacement, Back Frame: stap 11, afbeelding 1 van 1
    • You can now access the back panel and the buttons on it.
  12. Panasonic DMC-FZ70 Back Frame Replacement: stap 12, afbeelding 1 van 1
    • To remove a button, lightly press its front face and it should detach with ease.
    • To put a button back into the camera, press on front its back face until it snaps back on.
Conclusie
Emily Kuzmicky
445 Reputatie
2 handleidingen geschreven
Cal Poly, Team 21-3, Maness Winter 2017 Lid van Cal Poly, Team 21-3, Maness Winter 2017
CPSU-MANESS-W17S21G3
6 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 21
Altijd: 983
