Ga door naar hoofdinhoud
Panasonic D-snap SV-AV50 Screen Replacement
Wat je nodig hebt
  1. Panasonic D-snap SV-AV50 Screen Replacement, Screen: stap 1, afbeelding 1 van 1
    • Open and rotate the screen, then remove the screw(3.5mm Philips) indicated with a screwdriver.
    • Then, rotate the screen 180 degrees and remove the screw on the opposite side.
  2. Panasonic D-snap SV-AV50 Screen Replacement: stap 2, afbeelding 1 van 1
    • Remove the screw(2.6mm Philips) indicated on the top of the screen with the screwdriver. Then remove the corresponding screw on the bottom of the screen.
  3. Panasonic D-snap SV-AV50 Screen Replacement: stap 3, afbeelding 1 van 1
    • Pull the backing away from the screen as shown in the photo.
  4. Panasonic D-snap SV-AV50 Screen Replacement: stap 4, afbeelding 1 van 1
    • Unplug the black connector between the camera and the screen by pulling down.
    • For increased ease, use tweezers or forceps, as seen in the picture
  5. Panasonic D-snap SV-AV50 Screen Replacement: stap 5, afbeelding 1 van 1
    • Pull the screen away from the camera the same way that you removed the screen backing.
  6. Panasonic D-snap SV-AV50 Screen Replacement: stap 6, afbeelding 1 van 1
    • Use the screwdriver to remove the screw(2.46mm Philips) indicated.
  7. Panasonic D-snap SV-AV50 Screen Replacement: stap 7, afbeelding 1 van 1
    • Pull upwards on the screen border to remove it from the actual screen.
Conclusie
Zoe Hinck
29 Reputatie
4 handleidingen geschreven
Cal Poly, Team 6-19, Amido Spring 2012 Lid van Cal Poly, Team 6-19, Amido Spring 2012
CPSU-AMIDO-S12S6G19
3 Leden
12 handleidingen geschreven
Één opmerking
I need the LCD screen, can you helpme?
leon - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 1,062
